Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Aug 2003
    hi peeps,
    Here's hoping someone can help us out. The company is looking for a mobo with the ff features:
    1.) Core 2 Duo/Quad Core support
    2.) 4 memory slots
    3.) supports total memory of 8gb or more
    4.) 4 or more SATA ports
    5.) onboard video
    There are a lot of high end mobos out there, but all of them tend *not* to have onboard video -- which means we need to shell out an additional 1 - 1.5k for the PCI-Express video card. Since these boards will be used as servers, i really don't see the point of getting a 128/256mb PCI-Express card -- heck, we can surviveon 8Mb PCI-Express video cards if someone would make them.
    We've plum run out of PCI video cards, and i'm not really keen on buying second hand stuff, particularly electronics and computer stuff.
    Intel seems to be the only one making high end mobos with onboard video, but it seems all the newer models don't have the PS/2 and mouse ports any more. We'd prefer ones that have the standard ps2/mouse ports.
    tia
    2.) 4 memory slots
    5.) onboard video
    [SIZE=5]Intel BLKDG33BUC LGA 775 Intel G33 Micro ATX Intel Motherboard[/SIZE]
    [SIZE=3]http://www.newegg.com/Product/Product.aspx?Item=N82E16813121300
    [/SIZE]
    Model Brand Intel Model BLKDG33BUC Supported CPU CPU Socket Type LGA 775 CPU Type Core 2 Quad / Core 2 Duo / Pentium D / Celeron FSB 1333/1066MHz Chipsets North Bridge Intel G33 South Bridge Intel ICH9DH Memory Number of Memory Slots 4×240pin Memory Standard DDR2 800 Maximum Memory Supported 8GB Channel Supported Dual Channel Expansion Slots PCI Express x16 1 PCI Express x1 1 PCI Slots 2 Storage Devices PATA 1 x ATA100 2 Dev. Max SATA 3Gb/s 4 Onboard Video Onboard Video Chipset Intel GMA 3100 Onboard Audio Audio Chipset Realtek ALC888 Audio Channels 6 Channels Onboard LAN LAN Chipset Intel 82566DC Max LAN Speed 10/100/1000Mbps Rear Panel Ports PS/2 2 Video Ports D-Sub USB 6 x USB 2.0 IEEE 1394 1 x IEEE 1394a Audio Ports 3 Ports
    [SIZE=3]
    Damn newegg.com fonts.........
    [/SIZE]
    You can try looking at XFX gaming motherboards. These support dual-core or core duo CPUs and have onboard Nvidia 7050 or similar video card (share memory). It also has PS2 kb/mouse ports. The model I got didn't have any serial nor parallel ports but had four USB ports at the back plus a couple more onboard for the front. I don't remember the number of memory slots nor SATA ports it had though.
    I have bought one and using it in the office which is handy for doing photoshop work.
    You can try inquiring at INFONET Computer Center in V-Mall
    Tel: 725-5311; 725-2889
    Look for "Newton"
    Just just checked my mobo... it has two memory slots (4gb max) and 4 SATA ports.
    XFX nForce 610i with geforce 7050.
    Jun 2006
    high end would be Gigabyte.
    but the only Gigabyte intel compatible board with decent videocard built-in is the one with 9400M chip.
    Jun 2006
    Sep 2004
    Just make sure you use a 64-bit OS to fully utilize the 8gig memory capacity.
    AMD:
    ASRock A790GXH/128M AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard
    Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 / Athlon X2 / Athlon 64 / Sempron FSB 2600MHz Hyper Transport (5200 MT/s) Chipsets North Bridge AMD 790GX South Bridge AMD SB750 Memory Number of Memory Slots 4×240pin Memory Standard DDR2 1066*/800/667/533
    *Support with AM2+ CPU Maximum Memory Supported 16GB Channel Supported Dual Channel Expansion Slots PCI Express 2.0 x16 2 (green * x16 mode, orange * x4 mode) PCI Express x1 1 PCI Slots 2 Storage Devices PATA 1 x ATA100 2 Dev. Max SATA 3Gb/s 6 SATA RAID 0/1/5/10/JBOD Onboard Video Onboard Video Chipset ATI Radeon HD 3300 Onboard Audio Audio Chipset VIA VT1708S Audio Channels 8 Channels Onboard LAN LAN Chipset Realtek 8111DL Max LAN Speed 10/100/1000Mbps Rear Panel Ports PS/2 2 Video Ports D-Sub + DVI HDMI 1 x HDMI USB 4 x USB 2.0 S/PDIF Out 1 x Optical Audio Ports 6 Ports
    AMD:
    GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard
    Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 FSB 2600MHz Hyper Transport (5200 MT/s) Chipsets North Bridge AMD 790GX South Bridge AMD SB750 Memory Number of Memory Slots 4×240pin Memory Standard DDR2 1200 / 1066 / 800
    (Whether 1200 MHz memory speed is supported depends on the CPU being used) Maximum Memory Supported 16GB Channel Supported Dual Channel Expansion Slots PCI Express 2.0 x16 1 x PCI Express x16 slot, running at x16 (PCIEX16_1)
    1 x PCI Express x16 slot, running at x8 (PCIEX8_1) PCI Express x1 3 PCI Slots 2 Storage Devices PATA 1 x ATA100 2 Dev. Max SATA 3Gb/s 6 SATA RAID 0/1/5/10/JBOD Onboard Video Onboard Video Chipset ATI Radeon HD3300 graphics built-in 128MB DDR3 1333MHz SidePort Memory Onboard Audio Audio Chipset Realtek ALC889A Audio Channels 8 Channels Onboard LAN LAN Chipset Realtek 8111C Max LAN Speed 10/100/1000Mbps Rear Panel Ports PS/2 2 Video Ports D-Sub + DVI HDMI 1 x HDMI USB 4 x USB 2.0 IEEE 1394 1 x IEEE 1394a S/PDIF Out 1 x Optical Audio Ports 6 Ports
    AMD:
    BIOSTAR TA790GXB A2+ AM2+/AM2 AMD 790GX ATX AMD Motherboard
    Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom X4 / Phenom X3 / Athlon 64 / Sempron FSB 2600MHz Hyper Transport (5200 MT/s) Chipsets North Bridge AMD 790GX South Bridge AMD SB750 Memory Number of Memory Slots 4×240pin Memory Standard DDR2 1066 Maximum Memory Supported 16GB Channel Supported Dual Channel Expansion Slots PCI Express 2.0 x16 1 PCI Express x1 2 x PCI Express 2.0 x1 PCI Slots 3 Storage Devices PATA 1 x ATA100 2 Dev. Max SATA 3Gb/s 6 SATA RAID 0/1/5/10 Onboard Video Onboard Video Chipset ATI Radeon HD 3300 Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset Realtek 8111C Max LAN Speed 10/100/1000Mbps Rear Panel Ports PS/2 2 Video Ports D-Sub + DVI USB 4 x USB 2.0 Audio Ports 3 Ports
high end mobo with onboard video
