Results 1 to 7 of 7
    My computer says power is limited blah blah blah, but sometimes the device does work.
    Help please...
    iam3739.com
    Sep 2005
    Ano nakalagay pre?
    It could be the USB port itself. If your device needs USB 2.0 and your port is only 1.0 or 1.1 ... you need to either buy a PCI card with USB 2.0 ports or upgrade your motherboard.
    I sometimes get that message with some Dell laptops whenever I hook up my unpowered 2.5" external usb2 hard drive. I just ignore it and continue which seemed to have no ill effects on the hard drive.
    Okay naman before... I think it's software related though...
    iam3739.com
    Sep 2005
    A USB port can supply 5 Volts DC to peripherals. However, the current is very limited ... initially only 100mA (0.1 Ampere) and upon demand, up to 500mA (1/2 Ampere). As you can see, it can only supply a maximum of 2.5 watts.
    If your peripheral is connected through a hub, try plugging it directly to the computer's USB port.
    Sir,
    Direct na po sya...
    iam3739.com
Ineffective USB Connection
