Results 1 to 10 of 19
- May 2006
- 141
October 17th, 2006 07:25 PM #1Guys need help.
I need to recovery a damage or non working hard disk co'z we need the stored files.
here is the status of the Hard Disk:
1. Cannot be read on Cmos/Bios
2. Physically I Think may na sira co'z prang may mga mugmog or dumi akong nakita.
I now possible pa ito ma recovery atleast kahit yung ilang laman.
I just don't now kung saan reputable Technical shop pwede.
Tulong naman po mga computer Wizard dyn.
Thanks & God Bless!
October 17th, 2006 07:35 PM #2
http://www.quetek.com/ file scavenger v3.0
try that! check the site for more details
http://www.quetek.com/download.htmLast edited by radiazone; October 17th, 2006 at 07:39 PM.
October 17th, 2006 07:42 PM #3
Try troubleshooting first with the ff
1.) Try the particular hard disk on other computers first. We have a busted motherboard here which cannot read or recognize (at "cmos/Bios" )any hard drives or optical drives attached to it. Tried it on another different working motherboard and the hard disks are still functional.
2.) If you're hard drives are PATA. (parallel ATA), maybe you did not configure the jumpers on it to indicate whether its a master, slave or master w/ non ATA slave, etc.. Consult the website of the hard drive's manufacturer regarding the jumper settings.
October 17th, 2006 07:43 PM #4
Kung hindi na madetect sa CMOS paano mo pa mapapagana yung hard disk?
Sa akin kasi pag nasira yung HDD swap and try ko muna sa ibang computer pag hindi na talaga gumagana sa ibang computer palitan na.
October 17th, 2006 08:05 PM #5
Ganito lang ginagawa ko diyan chief:
1. Slave config
2. Try ko ipasok sa external HDD enclosure
IDE po ba yan o SATA?
October 17th, 2006 08:05 PM #6
pero do we have any shop dito satin na kaya magrepair ng HDD just in case?
October 17th, 2006 08:11 PM #7
Meron po akong alam na nagrerepair sa TPC (http://www.tipidpc.com/). Search niyo na lang po doon chief. Doon ko nabasa dati yung service na inaalok na HDD recovery service.
October 17th, 2006 09:15 PM #9
try mo lang..
i've read this somewhere, lagay mo sa freezer yung HDD overnight... no joke. tas install mo ulit. baka gumana.
October 18th, 2006 12:05 AM #10
i think for this instance... once the hard disk (HDD) is not detected in the bois. How can you recover a file from the HDD?.. so basically, the HDD is damaged and no more files can be recovered at this point.
Try mo ibagsak sa floor with carpet yung HDD or lagay mo sa Freezer for an hour.. This is the last option done by some technicians. for after freezing the HDD for an hour or so, it may still run for 2-3hrs much enough time for the files to be recovered.
Tesla Philippines
