Results 1 to 7 of 7
Threaded View
February 28th, 2014 03:51 PM #3
Medyo mahina mag- explain electrician mo, tsk- tsk- tsk.
Ganito na lang:
1. The main equipment / server and all electrical equipment should be properly grounded. Sabihin mo lang
sa electrician 'yan at kung talagang marunong siya, alam niya na ang gagawin.
Kaya ka naga- ground, kasi 'yang "grounding or earthing system / connection" mo sa building ay
"floating" and / or "may sayad". Your electrician should be able to find this fault and fix it.
floating - poor connection of wires/conductors; interrupted flow of electric current
may sayad (grounded) - unintended flow of electricity between two objects / bodiess
Lahat ng electrical system or equipment ay may "grounding wires" o terminal man lang to tap these
grounding wires. Kung properly wired ang electrical system niyo, meron dapat grounding wires 'yan.
Usually, Green ang color ng insulation ng mga grounding wires. Pwede naman ipakita sa iyo
ng electrician 'yan. Just open an outlet and look at the wires inside.
2. Yes. kailangan talaga ang "full" metal to metal contact sa mga Grounding Systems.
You really have to scrape the paint. Paints are insulators, metals are conductors.
3. It's not advisable (well, I won't) to connect grounding wires to sprinkler pipes.
Hindi kasi siguradong lahat ng pipes / tubo ay metallic. Decades ago, ginagawa ito kasi nga
hindi pa uso ang mga PVC Pipes. Kapag somewhere eh na- interrupt ang connections ng mga
metal pipes, interrupted rin ang Grounding System mo. Diyan lumalabas ang mga "floating".
4. Yes. Merong "mark/s" diyan sa aluminum casing na 'yan where you should tap the Grounding Wires.
Imposibleng wala, unless, the aluminum casing is not meant for electrical equipment.
Above all, kailangan mo munang ayusin ang "Grounding System" niyo bago ka mag- connect ng mga
Grounding Wires sa mga equipment. Ask the Building Maintenance Engineer re the building's Grounding System.Last edited by joemarski; February 28th, 2014 at 03:54 PM.
Tesla Philippines
