Results 1 to 10 of 24
- Sep 2014
- 57
January 17th, 2018 05:30 PM #1I have a Firefly AC/DC electric Fan, Model FEL 631, I have disconnected the wires from the batteries without noting their polarities.
I understand that connecting the batteries wrongly will burn the circuit.
Would someone who has this electric fan please advise me which terminals of the batteries the wires shall be connected to.
it has 2 battery compartments, one has a blue wire and a red wire, the other has a blue wire and a black wire.Last edited by bigT; January 17th, 2018 at 05:43 PM. Reason: Description added because unable to upload pictures
January 17th, 2018 06:19 PM #2
Here's an educated guess:
-------(red wire)-------------(+)[Battery 1](-)----- (blue wire)-----(+)[Battery 2](-)-------------(black wire)---------
- Sep 2014
- 57
- Jul 2013
- 2,450
January 18th, 2018 10:05 AM #4Aren't DC motors capable of turning in either direction? The polarity is there only to turn it in the right direction (e.g. for electric fan to blow air towards us, for toya cras to move forward).
It won't be toasted in reverse polarity, AFAIK. It will just turn in the wrong direction.
January 18th, 2018 10:28 AM #5
if you say there are 2 battery compartments, that means there are also two batteries... and this also means that these batteries are in series (based on your description), now connect the red wire to the positive terminal of the first battery, then connect the black wire to the negative terminal of the second batery, that leaves you the negative terminal of the first battery and the positive terminal of the second battery without wires right? you now connect the blue wire to the negative terminal of the first battery and connect the other end of this wire to the positive of the second battery, there you go...
January 18th, 2018 10:51 AM #6
That may be true if we're just talking about a simple circuit involving a battery and a DC motor. But you must not forget that the portable fan in question also has a built-in charger. Connecting the batteries the wrong way, lead-acid batteries no less, could damage the charging circuit or may in fact, hurt someone. If it does not blow up the charging circuit immediately, applying power through the AC plug with the batteries reversed will certainly fry something.
- 53,883
January 18th, 2018 10:58 AM #7errr... might i inquire,
why did you distruncate it, sir?
i mean, it's not easy to even open that appliance in the first place. i've done it myself in the past.
but if all you did, was to open the battery compartments and disconnected the wires from there, i think oj's diagram is correct.Last edited by dr. d; January 18th, 2018 at 11:04 AM.
- Nov 2009
- 3,503
January 18th, 2018 12:23 PM #8
- Sep 2014
- 57
January 18th, 2018 02:37 PM #9
- Sep 2014
- 57
January 18th, 2018 02:45 PM #10Last edited by bigT; January 18th, 2018 at 02:51 PM. Reason: Note added,
