Results 1 to 6 of 6
- Aug 2003
- 9,720
July 24th, 2014 03:10 PM #1Hi All,
i recently saw a page/blog with pretty basic setup -- the guy basically had a deep cycle battery hooked up to an inverter/trickle charger, with an inverter on standby in case of power outages. If you don't want to fool around with solar panels this seems a practical setup.
What do you guys think? Any off-the-shelf charger/inverter should work right, assuming the volts/amps/wattage line up?
tia
- Jun 2005
- 3,774
July 24th, 2014 03:23 PM #2we had the same setup before. inverter is hooked the car battery and car is on idle. power was supplied to an electric fan and a black and white TV and some lights.
we used it in the 90s until nasira yung inverter. now im looking for a 12vdc to 220vac inverter
Sent from my Thrill 430x using Tapatalk 2
- Jun 2006
- 1,139
July 24th, 2014 03:41 PM #3You can use an old ups with a dead bat, change the battery to a much larger capacity and connect it to your lights. Every brownout your lights will automatically change to battery mode and go back to standby mode when the grid returns.
Just dont expect the ups to charge the batteries overnight. Some ups on charges the batteries at 1 or 2 amp
- 53,883
July 24th, 2014 08:01 PM #4..tried it before. It works. The difficult part was to isolate the appliances that will be powered by the battery. Otherwise, your contraption will power the entire neighborhood and run out of power very fast, if it doesn't blow a fuse first..
- Aug 2003
- 9,720
July 25th, 2014 10:40 AM #5
- Jun 2006
- 1,139
July 25th, 2014 11:18 AM #6Yes, its not designed to handle flooded batteries that has a float voltage of 14.6. A sealed type battery has a float voltage of 14.4v.
Lead acid Battery fumes tend be more corrosive and explosive if charged in an enclosed space.
Tesla Philippines
