Results 1 to 10 of 10
    Im planning to free space sa home office and planning to ditch my HP 4 in 1 printer and replace it with wireless type printer.
    Kung meron copier better but most importantly is meron airplay.
    So basically copier/scanner/printer with airplay.
    I am using HP3510 at home. It has its own modem or you can use your home network. Has mobile app support as well so you can print from your smart phone or tablet.
    Thanks. Hanapin ko nga yan. So kailangan meron naka open pa na computer to serve as server? Para pwede mag print or diretso from tablet/phone pwede na?
    Compact size na ba yan?
    Yun AOI na HP ko Sa bahay meron pa fax eh. [emoji16]
    No need bro. The printer has a wireless modem itself that allows you to connect your laptops/gadgets over the air. If you have a wifi router, you can connect the printer to the router as well. I bought 2 or 3 years ago for P5K so there could be newer models now.
    Based sa internet pag hinde daw airprint mahirap daw connect or print from I gadgets.
    Yup, it is air print. Print, scan and copy, no fax. Ink price is reasonable too.
    meron bang air print na continuous/refillable ink?
    Jan 2009
    If it's just basic printing (laser, b&w prints) with Airprint, there's the HP P1102w. Emphasis on the 'w' in the model. There's the P1102 model without wireless... that one obviously does not support Airprint.
    We use it to print receipts, test papers and everything that doesn't require color.
    Mahal yata ink niyan
    Jan 2009
    Uses a toner. Expensive if you get the genuine HP ones.
    When we ran out of the included HP toner, I went out and bought a replacement/compatible toner cartridge. Last time I bought one (maybe around 1-2 years ago), it costs 1k. It still has around 50% toner left.
Cheapest-"smallish" printer with air print.
