Results 1 to 10 of 88
November 6th, 2022 06:09 PM #1
Hey, can I you a question? In IFTTT I can see an applet that trigger when battery is 15% which I can use to turn on my smart plug. But I can't find a trigger to turn off smart plug when the battery reached 80%.
I'm planning to use my spare tablet as a under the monitor display which will be always Screen on like a smart clock and will dump some of the functions like spotify on that small tablet. So it will be perpetually connected to a charger with a smart plug.
Do I need an IFTTT pro to see trigger for 80% battery?Last edited by BratPAQ; November 6th, 2022 at 06:11 PM.
November 6th, 2022 08:05 PM #2
Had an errata in my previous post. I was actually using Tasker (and not Macrodroid) with IFTTT. Although I do use Macrodroid for other automations as well, just not on this battery stuff.
So Tasker ties into the Android system to read the battery percentage and sends out a web request to IFTTT to turn on/off the smart plug based on the conditions I've set (ie. Time of day and battery %).
I didn't use the native IFTTT Android integration because, as you've discovered, it didn't have a selection to define an upper battery limit. Until then, it has to be done the slightly harder way.
November 6th, 2022 08:43 PM #3
Thanks for the suggestion. I will try your way. I did it just now using notification. Tasker will create a notification with certain keyword if battery reaches certain percentage and IFTTT is configured to listen to that notification.
Your solution is more elegant and clean. I'd try to learn that.
Tesla Philippines
