Page 1 of 5 12345 LastLast
Results 1 to 10 of 41
    Nag open na ako ng ports sa modem ng PLDT hindi ko pa rin ma-access CCTV ko via internet.
    Signature
    call pldt and tell us their reply..
    Some cctv requires port forwarding with specific port to be opened like a suffix ip: port.
    Btw whats the pldt modem ip, bridge mode static wan, routed/mer, pppoe, dhcp? Port forwarding is useful if you are behind a firewall or another private ip separating the wan.
    Plus the CCTV will require a static IP address. Normally it will require a router plug into the modem and configure the router (fort forwarding, static IP address and the open port used).
    but shouldn't pldt have done all these, making sure it works fine, before they left?
    No, carrier is limited to internet transport only. Cctv is a client app., not unless the cctv is part of the internet package.
    Mar 2013
    maybe you could try to use another router instead. but you have to change the fibr modem to bridge mode.
    my fibr modem i have to call pldt for them to make this change. nagtry ako dati palitan nawala lang connection ko. sila lang daw makakapag change remotely.
    There are cctvs that hook to centralized servers na kahit dhcp or behind the router, they should work. I guess these fibr modems are dhcp on both WAN and LAN thats why the cctv couldn't connect. Bridging the router is one solution and its also ideal to have a static ip on WAN to make it more visible over public iP.
    naka port forwarding na pero di pa rin ma-access.
    parehong naka pldt fibr sa office at bahay. pero parehong hindi ko ma-view cctv sa bahay and office.
    i can access the admin config page of the pldt modem. pwede ko bang palitan to bridge mode sa modem lang without informing pldt?
    Signature
Can't remotely access my CCTV after upgrading to PLDT Fibr
