Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    My MB is MSI K8N SLI. Right now, I have 2pcs of 512mb ram installed. I want to add another 1gb ram. Is this possible with my motherboard?
    ang alam ko pwede hanggang 4 gig naman kaya niyan
    Sa pagkakaalala ko kasi sa mga lumang motherboards, dapat by pairs ang kinakabit na memory module. Pwede na ba kahit hindi na by pair ngayon?
    Dec 2003
    pwede, afaik having the same pairs with same speeds ay magiging dual bridged ang memory, so if 3 sticks lang at different sizes mag default to single bridged (or whatever they call it) na ang memory mo.
    para sakin la naman syado maramdaman kahit naka dual bridged ang memory.
    two sticks would be operating as dual channel (must be same spec) while the other one is in single channel mode
    karamihang board ngayon tatlong slot na lang para sa memory.
    dual channel i believe is the term. as long as they have the same speed and are of the same type, they should work together. best thing to do is to try them out, if they work then good for you.
    Quote Originally Posted by moe View Post
    pag dual channel pwedeng mix, 256MB PC266 ipareha mo sa 512MB PC400 ... etc. same with the DDR2 memory.
    boybi, perif youre not after the 5% or so performance gain from Dual Channel, you can put any combination of ram into the mobo.
    based sa pix ng mb niya at dalawa ang 512mb sdram niya, kasya pa ang dalawa. Look at the lower right portion. Those are the SDRAM slots.
    Yep puwede maglagay ng isa pang 1GB.
Can the MSI K8N-SLI motherboard support 3 sticks of ram?
