Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 75
    Lately, I'm experiencing intermittent internet connection and I found out it was caused by this router. Whenever my browser returns a page cannot be displayed error or something similar, I'll have to turn OFF and ON the router and my internet connection will be back to normal. Can this be fixed?
    Oct 2007
    We have the same problem, im also using a linksys wrtg54g, but di ko alam if its the router or the modem yung problem, kasi meron naman wifi connection but walang internet connection, ganun din ang ginagawa ko, i turn off the router and the internet connection.
    I only turn OFF the router, not the modem.
    I am using the same router but its A-ok over here. Sometimes yeah I have to reset the router by plugging it out but after I plug it in its ok again. And it does not happen veryr often...
    I am not encountering any problem at all with my unit.....
    7505:bravo:
    I have had this problem. I have tried reflashing the router with an update for it's software. Same results. Solution, replaced the router. It was the same story with FOUR Linksys wifi routers located either in my home, my parent's home and at my two PC rental shops. All routers have been replaced by their TP-Link equivalents.
    I am currently using TP-Link brand routers and they have been dependable. Another plus is that TP-Link routers are very affordable. Downside, the configuration isn't as friendly to use but at least help/explanation for each setting is still available.
    So it seems it doesn't have a fix.
    Too bad.
    Oct 2008
    TS, wala ako ma contribute ha?
    dito na lang ako mag ask...
    i am planning to buy a router for my new home. would any of you recommend a good yet reasonably priced router, please? i am planning to buy one today or tomorrow or as soon as globe would be able to install its line...
    also, i need one that's easy to install...easy to troubleshoot.
    gaya nga ng sabi ni GH, try mo muna i flash yung router. if it does not work, then i think its a hardware problem na.
    Quote Originally Posted by ab_initio View Post
    TP-Link. Choose the "N" band routers especially if you are planning to setup a whole new wifi-network. If you are familiar in configuring routers, you shouldn't have much trouble with it. There is also a quick setup option within the router so if you already have the usual information with you, it would guide you through the process.
Linksys WRT54G problem [merged threads]
