Results 1 to 10 of 14
October 10th, 2019 11:57 AM #1
Need suggestion in building Gaming PC. Something between mid range and high end. Also, what type of TV would be good for gaming? What are the specs that we should look at when considering a gaming TV? Size would be 55" to 65".
- Sep 2016
- 2,348
- Oct 2012
- 4,851
October 10th, 2019 01:49 PM #3Tv specs should have at least refresh rate at 120Hz....
You can search gaming cpu you preferred and check the hardwares then you can start from their... like sa Asus Rog, HP omen, MSI infinite and ASUS predator are good reference...
Good luck sid!
- Sep 2016
- 2,348
October 10th, 2019 02:31 PM #5Maybe you would like this setup. Ito balak kong buuin though wala pa budget.
cpu: AMD Ryzen 5 3600
motherboard: MSI B450M Mortar Max
ram: GSkill Ripjaws V 16GB 2x8GB 3200Mhz F4-3200C16D-16GVKB
ssd: Adata XPG SX8200 Pro 256GB NVME m.2
hdd, WDC Blue 1TB
gpu: MSI GTX 1660 Ti Gaming X 6G Twin Frozr
psu: Seasonic Focus Gold 550FM 80+ Gold
case: Tecware M3 MATX Tempered Glass (Black)
Not sure about the gaming TVs though, maybe the likes from Samsung or LG are good. Also, you might want to change the gpu to a stronger one (RTX maybe?) if you are going to play on a higher resolution (4K).
October 10th, 2019 05:28 PM #6
October 10th, 2019 05:35 PM #7
Stay away from msi b450m.
Yung bios chip is mababang capacity lang. Yung mga future bios upgrades na kelangan to run ryzen 3rd gen correctly is most likely di na kasya.
- Sep 2016
- 2,348
October 10th, 2019 06:07 PM #8
October 10th, 2019 06:26 PM #9
October 10th, 2019 07:08 PM #10
I upgraded from an AMD FX-8350 to an Intel i5-8600 not too long ago. That plus 16 GB DDR4 2666 RAM, WD Blue M2 512GB SSD, new copy of Windows 10.
I'm also still using my existing parts: 6GB GTX 1060, 2TB and 500GB hard drives, gaming keyboard n mouse......
Once I get my fill of the STALKER and Fallout 4 universe, I'll upgrade from the GTX 1060 to the RTX 2060 line.
