when to replace fan & motor assembly
When do you know it's time to replace the fan & motor assembly. I have a 2002 Urvan and the casa recommended replacing the fan & motor assembly kahit wala akong naririnig or nararamdaman na kakaiba. What do I have to look out for to be sure it is time to replace? Ang mahal kasi, P13,717.50 for a new fan & motor assembly + P983 sa labor.
Re: when to replace fan & motor assembly
luloym
alas, i don't think it's in the manual or maintenance schedule. in my experience, i was having overheating problems in my sentra. i thought my fan was ok, until the mechanic showed me a new unit and just how strong the wind should be.. and if you are willing to gamble, you can probably save a lot (over 50%) if you have it done outside the casa. the fan is a low-tech part; any decent mechanic should be able to do it. just be sure you get a good replacement (japan sana and not taiwan).
actually, before the overheating, i first brought the car to the casa for another problem. they fixed the problem, and recommended i replace both fans because they were about to fail. hindi ako naniwala dahil malakas pa naman ang hangin. nag-overheat. pinagawa ko sa labas. pinalitan ko yung mahinang fan. after a few weeks, the other fan also slowed down and i had to replace it.
i guess it means, if their mechanic says replace it, we replace it.
thanks. buong assembly kasi pinapalitan. from my experience sa casa, laging buo kung mag-replace kahit isang part lang may diperensya. don't know if I should just replace the fan and the motor is still okay, or if I should replace the whole assembly. how do I check?
luloym
Usually sir yung motor po pinapalitan.. may mga ibang motor na pwede repair.. pero if I where you replace na lang ng fan motor... Sa sentra ko dati Series 4 I think 900, replacement lang, ang fan motor then ako na lang nag replace.. Cguro P200 lang labor ng ganoon or 250
kung wala namang tama yung blades, just replace the motor and have it done outside. going prices ng bnew motors na japan is around 3-4k. Kung taiwan (circuit brand), between 1-2k depending on the model. Labor mura lang baka less than P300 lang yan.
pwede ba sa urvan yung bnew japan motor for 3-4k. where can I buy one?
pabaklas mo muna yung fan assembly, remove the blade then remove the motor itself para may dala kang sample then check with auto supplies.
kompressor
pinapa-gawa ko to. parusa kung sarili gagawa.
motor lang ang pinapalitan, unless your housing is damaged..
some motors can be rebuilt. ours can't. throw-away fan motors..
Unless there's something special with that fan and they are willing to warrant it for 10 years that price isn't justified as is.
Try your other options outside. Fans shouldn't cost that much.
Wow .. a fan motor worth its weight in gold!
Marami sa mga auto supply nyan sa labas. Buy there and have your neighborhood greaser replace it.
