guys tanong ko lang anong tamang hanging sa gulong na size is 205-16- 45. kasi I'm putting 30 psi tama ba yun? thanks
Are these stock tires or upgrades?
Did you plus size correctly?
If you've plus sized, tire pressures should still be the factory specs, regardless of whether you have 15's or 18's. I do believe that the correct recommended psi levels are written on both your door sill and your owners manual.
30 psi pwede na
30 or 32 psi ethier sa dalawa puede.
same size ng akin yan.30/30 karga ko.
Napansin niyo ba na the question was asked about 4 years ago?
Bakit nga ba may pilit na bumubuhay ng lumang threads?
