"Defective" Headlights (Civic)
Need help.
My right headlight keeps on konking out.
In a month i replace the fuse at least 2 times.
Then i noticed that the 'fuse box' (made of hard plastice?) is slowly showing signs of meltdown.
I have the superwhite type na headlights.
What can i do? Do i need to replace headlights to honda origs?
I already had instance of driving at night with no lights.
Major safety issue lalo na pag lakas ulan.
Hirap pala pag bulag.
(is there a similar topic on this here or in the car electronics thread?)
Re: "Defective" Headlights (Civic)
How many watts are the bulbs you are using? Did you install a relay for them? I would recommend switch back to OEM bulbs or OSRAM Silverstars (stock wattage).
Yes, meron relay.
I'm using OSRAM Silverstar stock wattage lang pero mas malakas kesa stock bulbs.... OK sya.... di pa masusunog yung socket mo..... medyo mura pa.. nasa mahigit 1K lang.
