4 Attachment(s)
Please Help with the Leak! (Image inserted)
Hi po again and again :(
After driving the car last week which was this post --> https://www.tsikot.com/forums/other-...appear-108251/
nagkaroon po ng leak! ma-identify niyo po ba san sya nanggagaling and ano po dapat ipaayos? Sorry if kahit yung basic hinde ko alam... Kapapaayos ko lang po sa Casa nung January sa powersteering and Rack n Pinion, sakop kaya ng warranty ito? :(
Attachment 36735
Attachment 36736
Attachment 36737
Attachment 36738
My Car is a Civic 2010 model
:help:
Re: Please Help with the Leak! (Image inserted)
Liana
baka leak galing sa PS pump oil seal.
try to visit the Honda FD thread... yan talaga ang sakit ng mga civics
Nagbabawas PS fluid?
yung picture mo i think is the tranmission. so guessing kami either leaking pa nga yung power steering mo or baka nagpapawis na transmission so gasket.
sean-archer
Yan po ba yung nasa left side na pula yung cover? ung may upper and lower? hinde naman po bawas nasa line parin po.. Dati po kasi isa yung powersteering sa pinaayos ko sa Casa which is sa passenger side yung leak, ngayon wala na. Yung leak ngayon is sa gitna na po..
babkalakal
Dalawa po kasi yung inayos ng casa last january, Powersteering (passenger leak which is okay na wala na ngayon) and yung sa Gearbox or transmission ata yung pagkakaalala ko, which i think is dun nanggagaling ung leak, sa gitna po xa.. Babalik ko po xa sa casa sa friday, sana pasok pa sa warranty..
Thank you po for checking it out! sasabihin ko po sa casa ito.
Hard to tell, the color of fouled PS fluid and axle oil is almost the same when smeared to aluminum alloy engine.
One thing for sure, its a "last-touch" job by casa-with more reason to suspect on poor workmanship, either they did overfill the PS/ damaged a gasket, or axle drain plug was improperly seated/did not replace washer or use threebond gasket.
Kindly post the receipt po to check the latest job done and narrow down the suspects.
I like the orange fat cat
Liana
I hope maayos na problem. That civic model is a good car by the way. I got to own 2 of these cars way back. And yes, steering naging issues ko din. Even the one I own at present, steering pa rin haha.
if you haven't brought it back yet, do so now.
it appears to be a backjob.
if you attempt tinkering with it, or allow someone else to tinker with it, the backjob warranty may be void.
2 Attachment(s)
UPDATE!
Went to casa and let them re-check the leak and sabi it's in the Crankshaft and yung previous kong pinagawa is wala duon ung leak at need daw ibaba ang transmission which is really costly.. :(
Attachment 36757
Attachment 36758
Pina-remove ko pala yung ATF dyan kasi kakapalit lang ng ATF ko..
For now, pinalagyan ko na lang muna ng oil.. How much po kaya if sa labas ko ipagawa? Yung labor po how much would be the cost outside casa?
