ano kaya problem ng car ko, pag low gear sya, hindi pino ang rolling nya from stop, nagje-jerk eh. kaya linalaro ko yung clutch para ayos ang start...or from 1st gear...pero afterwards ok naman. thanks for the input!
I have a similar problem. It does not happen everytime, it happens normally when I have used the clutch a lot. One of the possible cause is uneven wear of clutch. Worse case may warp or crack ang flywheel, pero unlikely daw iyon.
Ito nga ba talaga ang cause? Also what if hindi pa naman nag slip ang clutch ko. Should I already look into replacing or having my clutch already serviced because of this. Or just wait until the clutch wears out?
jkyamog,
The fact that hindi sliding clutch yan...baka hindi nga clutch....but that would be difficult to assess....if I were you, having the clutch checked would be a better option than getting stranded because of a faulty clutch (magkano ba mag pa-tow at an cost ng abala sa tumirik na sasakyan).
Philpogi,
Does your car have engine rev problems at idle? Kun meron din at ito ay carburated engine, it could be dirty carbs....baka me konting bara ang carb jets....try carb cleaners and some oiling of the carb mechanicals too.
my 2 cents. hth
thanks. i will try to have my clutch checked. although it does not happen always. I am actually trying to look for other spots of the problem. yung ba mas madali galawin tapos ibalik if nothing happens.
Fuel injected ang engine ko eh, and the jerking just happen at very low speed. Parang ang hirap timplahin ng clutch. At mid to high speed no problem naman. The problem is kakapalit lang ng clutch disc ko mid last year. I am not a clutch driver too. Naku ano kaya sira nung akin?
if you feel na yung clutch yung sira then dapat palitan na. minsan kinakain nya rin yung flywheel which sometimes has to be refaced. this will only add to your costs and can be avoided with earlier maintenance.
saan ok magpacheck and gawa ng clutch? Sa akin is local terrano. kung sana puwede ay malapitlapit sa south. one option is Nissan Westgate, pero ang alam ko Nissan casa is not that good. Actually I would rather prefer hindi casa, not because of the cost. Kasi sa casa at times you can't see what they are doing. malas mo lang kapag ojt pa ang nag service sa car mo.
I can source out the parts, likely available naman iyan sa Advance sa pasay. Pasay area for me is ok too.
speedfix do you do clutch service? if you do please pm me the labor charge. thanks.
yup, we do tranny replacements:) i'll pm you now!
palyado ba siya baka madumi lang ang injectors mo o kaya kailangan magpalit ng fuel filter
fuel filter....every kailan ba ang palit? hindi kaya eto nga?
