Results 1 to 10 of 24
October 12th, 2017 09:25 PM #1
mga sir,may nabili ako elf na computer box,4hg1,bigla nalakas menor pag naka neutral,pag naka kambyo bigla na lng nakadyot,may naka pagkwento sa akin pwede daw pa convert sa manual,posible ba yon?ano po gagawin para maging manual na?thanks!!!
- Apr 2008
- 6,235
October 12th, 2017 10:07 PM #2I don't profess to be an expert, but AFAIK for that to happen, you will have to change the injection pump to its mechanical type counterpart, most likely among other things too. Have you tried fixing the idling problem? A Bosch or Denso accredited diesel center should be helpful if your friendly neighborhood mechanic comes up empty. It might even be cheaper than converting to an inferior mechanical pump.
Sent from my SM-G900I using Tapatalk
October 13th, 2017 02:40 PM #3
dito kasi ko sa majayjay laguna sir,medyo malayo,try ko tanong sa nagcarlan,dami naman assemble jeep don,baka kaya nila.ala kaya epekto sa performance ng makina pag pina manual?
- Oct 2009
- 2,271
October 13th, 2017 03:43 PM #4pwede gawin manual yan may kinakatay din ung kapitbahay namin na ganyan matic pinapalitan ng manual tanny
- Jul 2017
- 381
October 13th, 2017 10:23 PM #6alam ko yung idling nyan control by computer box and meron din mga temperature sensor. hindi ko pa naencounter magconvert nyan kasi even injection pump controlled ng computer din
- Apr 2008
- 6,235
October 13th, 2017 11:52 PM #7I have never heard of people converting a 4HG1 from electronic to mechanical, though I have heard of this being done with the 4JG2 and the 1KZ-TE. Assuming you were able to successfully convert it to mechanical pump, expect a power decrease, higher emissions and most likely louder engine noise and higher fuel consumption.
For such problems, I normally consult Central Diesel. You can first call them or chat with them on Facebook to see if they can fix the problem without doing any conversions. I highly recommend them over doing a conversion, which can be hit and miss and definitely very costly.
- Apr 2008
- 6,235
October 14th, 2017 02:59 PM #9Quezon Ave beside Capitol Medical Center. If you're coming from far away, it would be wise to call first.
October 14th, 2017 05:54 PM #10
thanks sir,try muna ako dito sa mga malalapit,nakakatakot ilayo elf,baka mag ala montero,hehehe,bigla kasi nadamba pag sinumpong..
Tesla Philippines
