Results 11 to 20 of 95
September 20th, 2004 07:12 PM #12
Read on:
- Cranking up the boost on the 4D56TDIC
I'll just post the other washer mod threads when I find it, I knew PK posted a complete modification with pictures.
Tsikot Member Rank 4
- Feb 2004
- 1,704
September 21st, 2004 04:05 PM #13ungas, parang nawala na ata ang site na nag-host ng pics ni PK.
this is a very good and cheap mod. I have been using it for 4 months, solid.
i think i am one of the few who went to 4 washers. (or was it 3). basta whatever most of the guys did, i added one more, kasi medyo kampante ako coz i had a boost guage installed while putting the washer sets in.
andy
- Jun 2004
- 103
September 21st, 2004 06:19 PM #14How about increasing hte power of a 4d56 NA?
Are there any cheap way of doing it without bolting on a turbo and all that stuff?
- Feb 2004
- 1,704
September 21st, 2004 06:22 PM #15maybe you could go the intake - headers - exhaust upgrade route?
i have tried this on gas engine cars, but not yet on my diesel
andy
September 21st, 2004 06:35 PM #16
calcite::: Lucky you, there are many alternative ways. One that I could think of now is, oversized pistons, rings, sleeves to increase the displacement of 4D56 engines.
September 21st, 2004 07:04 PM #17
May use ba ang headers sa Diesel? I heard na it may have a negative effect daw. Any comments peeps?
September 21st, 2004 08:04 PM #18
notEworthy27: salamat sa clarifications. akala ko ay rebuild ng turbo...hehehehe...
Dieseler: if I remember correctly, DocDiesel mentioned in another thread that when the exhaust is modified incorrectly (masyadong malaking ang diameter pipes) torque will suffer...
(opinion ko lang po)
September 22nd, 2004 03:29 PM #19
don't oversize the pistons sa normally aspirated diesel engine. bababa ang compression ratio mo. you can only do that if you are installing a turbo to accomodate extra boost. sa gasoline engines, you can do that. it will accomodate more fuel and air to burn.
September 23rd, 2004 01:24 PM #20
yan 168... simple ways lang gusto ko indi un magastos hehehehe...and as much as possible ayaw pag pait or mag rebuild..mahirap yan pag nagka problema...lalong lalaki gastos ko.....
