Results 1 to 10 of 41
Threaded View
January 13th, 2005 11:18 PM #32
Glow plugs are used only to preheat the fuel prior to starting. If your engine is smoky, check for any gasket leaks.
Check also your thermostat if it is allowing the engine to reach optimal temperature.
If the engine is smoky only when cold, then you can pass it off as normal.
Tesla Philippines
