Page 1 of 3 123 LastLast
Results 1 to 10 of 29
    Dec 2014
    I need to buy a bus and I am considering either a China (Yuchai) or a Hyundai bus engine. Can you help me decide. Thank you.
    Aug 2010
    quite frankly, this is no brainer.
    Jun 2015
    Quote Originally Posted by charina80 View Post
    Philippines bus lol
    We tried china ones didn't work out for us cool electronics thought but in the shop always never tried Hyundai I'm pretty sure will hold up better than china
    Philippines bus lol
    reliability - Hyundai
    aesthetics - china bus
    pero wag mo ng dagdagan ang balang ipuputok sa atin ng china. hth
    Maganda din sana Philippine made buses kaya lang tinitipid at sobrang taas ng presyo sobrang tagtag din hindi komportableng sakyan pag long distance. Weekly akong bumibiyahe kahit de luxe ng Victory Liner na Ph made at China made hindi ako makatulog sa Korean made lang ng Fivestar ako nakakatulog.
    Jun 2011
    Yuchai it's one of the biggest engine manufacturing plant in the world... Afaik makers din yan ng WArtsila engines.. Wartsila engines is used by power plants in different parts of world... That runs contineously for years... Pero madami din makers ng Yuchai sa china.. Kaya alamin nyo kung Saan factory ng Yuchai ginawa...
    If I were you get a oem cummins engine nalang to be sure... China made pero matibay din... Ginagamit sa mga IH head.. Kta19 Ang engine model Na gamit.. Kung bus Lang, Ntaa engine Lang... Pag nag overhaul kayo hindi din naman mahal parts at madami na Kasi lumabas na cummins engine... Importante Lang magaling mag overhaul ng cummins engine ang mechanico na gagawa... Hindi uubra Mga mechanico ng sasakyan..
    bro wala ng kumukuha ng Yuchai engine sa mga malalaking bus company sa planta pa lang daw palit na agad either Hino, Nissan, MAN, Daewoo, Hyundai. Yung Cummins engine naman ni Partas laging nag-ooverheat dalawang bus ang sunod na nasunog
    Jun 2011
    May problema cooling system nyan.. Ang dami namin cummins engine, Wala naman problemA sa overheat.. Kahit full load load pa on prime power... Walang overheat...
    Jun 2011
    Meron din kami IH head... Surplus Lang na cummins KTA engine kinabit namin.. Hindi naman nag ooverheat.. aFAIK may breather kasi yan... Meron dapat nilalagay na bypass hose sa engine papuntang radiator.. Pag nag drain kasi sila ng water, nagkakaron ng vacuum or air pocket, kaya hindi nag cicirculate ang tubig.. Ganun din catterpilar engines...
    Jun 2011
    Yung mga heavy equipment like bulldozer, crane truck, etc cummins or weichai din engine nun... lta or cta engine gamit..
    Cummins engine di matibay. Madaling bumigay ang turbo, madaling masira injection pump, injectors, pistons, liners. At totoo di basta mekaniko pwedeng gumawa nyan, iba ang pag-set in injectors nyan, pag nagkamali ng pag-set ng injectors bali mga push rods nyan. Injector pump nyan 6000 hours lang bumibigay na, for replacement na. At huwag ka na umasa ng overhaul lang ng injection pump at mas mahal pa magpa-overhaul kesa bumili ng bago. Turbo nyan dapat laging proper warm up at cool down. Pag di yan alam ng driver/operator katok agad turbo nyan di man lang aabot ng 5000 hours operation yan. Pati radiator fan idler pulley shaft nyan mahina, undersized kaya nababali.
    First hand experience yan. Made in china cummins mahina!
Which is a better buy, China or Hyundai bus engine?
