Results 1 to 5 of 5
- Dec 2003
- 14
December 21st, 2003 03:49 AM #1WWW.BIGBALLS.COM.AU has a diff gear set for patrol gq/gu. there are 2 models to choose from 4.6 for tyres 33-35 and 4.8 for tyres 35-38. if i were to use 4.8 and my tyres are 315/75 x16 on 16x8 magwheels, will my hi-speed will be relatively slower? or should i use the 4.6 so my hi-speeed will not suffer? pls advse guys : )
- Dec 2003
- 14
December 21st, 2003 03:54 AM #2sorry guys for the wrong url, it is WWW.BIGBALLSOFFROAD.COM not WWW.BIGBALLS.COM my stupid mistake : )
- Jul 2003
- 58
December 21st, 2003 06:21 PM #3i would go for 4.88 since the stock 4.11 on stock tires, the maximum speed of 4th gear and 5th gear is almost the same.
December 21st, 2003 06:47 PM #4
Weight and aerodynamics are also factors which can affect both top speed and accelerations. You regear to maintain drivability. But keep in mind that a taller truck has worse aerodaynamics than stock and that bigger tires weigh more than the stock ones.
- Dec 2003
- 14
December 22nd, 2003 01:06 AM #5thanks a lot guys !!! : ) i would go for the 4.88 and can you refer someone that can do a 3 inch stainless mandrel?
