Results 1 to 10 of 37
Threaded View
September 10th, 2003 08:36 AM #7Originally posted by Jeepcruizerph
Hmmm, sir paano po yon? ano yung nasa loob nito?
hehe mono po ako kasi di ako mekaniko lols...pero I have good mechanic :D
If you want to make one to look somewhat like the AEROGAS device, just get a 6 inch length x 2.5 inch diameter of solid metal rod... it doesn't matter if its aluminum, steel, brass, etc (wag lang iron kasi rust lang). Drill a 3/4 inch hole at the center and goes along the 6 inch length and stopping about 1/2 to 1 inch from the other end. Using smaller drill bits, make several small holes. Get a hose fitting & some hose. Thread the fitting into the 3/4 inch drilled hole. Somehow attach the hose to the engine intake hose. SO now, you have your own "homemade" AEROGAS device. If you want to make it better, insert some metal mesh inside it to give some filtering ability.
Tesla Philippines
