Page 1 of 2 12 LastLast
Results 1 to 10 of 15
cRane01 Wiper linkage/assembly repair/replacement... August 31st, 2016, 09:29 PM
thephantom Re: Wiper linkage/assembly repair/replacement... August 31st, 2016, 09:53 PM
cRane01 Re: Wiper linkage/assembly repair/replacement... August 31st, 2016, 10:18 PM
sirkosero Re: Wiper linkage/assembly repair/replacement... August 31st, 2016, 09:59 PM
cRane01 Re: Wiper linkage/assembly repair/replacement... August 31st, 2016, 10:21 PM
sirkosero Re: Wiper linkage/assembly repair/replacement... September 1st, 2016, 01:26 AM
box_type Re: Wiper linkage/assembly repair/replacement... September 1st, 2016, 11:27 AM
jaypee10 Re: Wiper linkage/assembly repair/replacement... September 1st, 2016, 01:22 PM
RomeoAlpha Re: Wiper linkage/assembly repair/replacement... September 1st, 2016, 01:39 AM
cRane01 Re: Wiper linkage/assembly repair/replacement... September 1st, 2016, 02:42 PM
cRane01 Re: Wiper linkage/assembly repair/replacement... September 4th, 2016, 11:48 PM
rj91 Re: Wiper linkage/assembly repair/replacement... September 10th, 2016, 12:04 PM
cRane01 Re: Wiper linkage/assembly repair/replacement... December 27th, 2016, 09:49 PM
Fifiro Re: Wiper linkage/assembly repair/replacement... July 27th, 2017, 10:15 PM
dr. d Re: Wiper linkage/assembly repair/replacement... July 28th, 2017, 12:11 AM
    Aug 2015
    Hi sir/ma'am, Ask ko lang if saan po ba okay magpagawa/replace ng Wiper linkage. Lumalampas kasi yung Wiper ko sa windshield then pumapalo naman kapag sa bottom part ng windshield. Baka may recommended shop kayo in Makati/Evangelista? May napagdalhan ako na shop last time 5k linkage pa lang, orig daw kasi, hindi ko pinagawa ang mahal kasi.
    TIA po.
    Dec 2004
    Have you tried checking if perhaps the screw of the arm is just loose? Baka kasi yun lang ang problem kaya pumapalo since lumalaktaw sa ngipin kapag may movement
    Sent from my Nexus 7 using Tsikot Forums mobile app
    Aug 2015
    Quote Originally Posted by thephantom View Post
    Yes sir, mahigpit sya and tnry ko i-adjust yung arm kalog talaga yung 2 wiper arm. Salamat po.
    Jun 2005
    May linkage na tinda sa mga auto supply ah...
    Pwede ka din naman hanap ng surplus.
    Kutob ko maluwag lang linkages nyan
    Aug 2015
    Quote Originally Posted by sirkosero View Post
    Salamat sir sa suggestion, will try to find sa auto supply. Hindi ko alam kung saan pupunta. Thank you
    Jun 2005
    Naalala ko lang. A few years ago, may ginawa yung isang latero dun aa old corolla. Parang ganyan din. Ang ginawa nya ay may.pinalitan sya na plastic bushing dun sa wiper linkage.
    Feb 2005
    mahirap maghanap ng plastic bushing, malamang galing yan sa pinagbaklasan na same linkage din, iba-iba kasi sukat nyan bawat kotse... pag nasira ito yan ang dahilan kung bakit kumakalog sa suksukan o butas palabas sa kinakabitan ng wiper arm, at kung bakit lumalampas yung wiper...
    ps. yung sa corolla ko nga pala 750 lang (taiwan) brandnew sa toyorama, banawe
    Oct 2009
    sa vti ko dati ganyan din problema.minsan nabunot na nga ung linkage niya.binaklas ko.nagtanong ako ng isang buong asembly.2k hindi kasama ung motor mekanismo lang.ililipat nalang daw ung motor.hindi ko muna binili kasi inalok niya sa aking plastic bushing daw ng linkage un daw muna palita ko..80 pesos ang isa.apat yata un.pinalitan ko lahat.umokey naman siya..pero after 2 years bumalik naman sa dati pero sulit na sa 2 years diba.try mo muna palitan ung plastic bushing..
    sa las pinyas ako naka bili KINGSPORTS AUTO SUPPLY
    Quote Originally Posted by cRane01 View Post
    TIA po.
    matanong ko lang anong kotse sir?
    then, when you say lumalampas sa windshield sa ibabaw or sa left side part? kung sa ibabaw, malamang mali ung sukat ng wiper na nabili mo.
    kung sobrang baba naman, baka mali lang pagkakapasok ng wiper arm.
    Aug 2015
    Quote Originally Posted by RomeoAlpha View Post
    Honda City 03
    Left side lumalampas, pag number 3 yung speed nung wiper pero pag 1 lang hindi naman lumalampas pero pumapalo pa din sa bottom part nung windshield. Salamat sir.
Wiper linkage/assembly repair/replacement recommended shop?
