Results 1 to 8 of 8
- Aug 2006
- 19
August 30th, 2006 10:12 PM #1mga sir, yung lite ace namin nag wiwigle pag 40-50 na ko,bkit kaya gnun??
- Jun 2006
- 50
- Jun 2004
- 1,311
August 31st, 2006 02:17 AM #6
ilan taon na iyun lite ace mo?
mas maganda ipacheck mo sa talyer or sa casa, its possible worn na iyun following: ball joint, idler arm/pitman arm, tie rod end, suspension bushing, struts and shock absorber...
improper wheel alignment...
loose wheel bearing...
or simply low tire pressure lang...Last edited by chuaed; August 31st, 2006 at 02:19 AM.
August 31st, 2006 09:38 AM #7
madaming reason for wiggles eh... it can be a simple thing as uneven or oblong tires or busted suspension parts.
better yet if you consult your reliable suspension expert.
if you are in makati or south area, bukas na daw ang cruven...
- Jun 2006
- 50
August 31st, 2006 11:10 AM #8
