Quote Originally Posted by ripperripz View Post
Question: I have a lancer boxtype. Why is that my contact point wont last long. Bakit lagi burnout yung tip nung contact point. Any Idea/Solution para maayos ang problemang ito? Your answer will be a great help to my problem. Thanks
How can you say the your contact point "won't last long?".... If it's non- functional (as in it won't last long),- then you can't start your engine as it channels the spark to your spark plugs at the precise moment of the engine cycle....You can also adjust this by revolving your distributor. However, I suggest that you use a timing light to check or validate.
Normally, you just clean it(contact point) by running a fine sandpaper in between the contacts. And then, wiping it clean by cloth.
Are you using the right value for your condenser?
Is the resistor still in series with your coil? Or, was it bypassed?
3808:fish:
