Results 11 to 15 of 15
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 2nd, 2004 10:45 AM #11hmmm... i initially thought it would be a busted radiator also pero since napaayos mo na then try the waterpump next. replacement brands like gmb are ok and i've had good luck with them
if the compression test results are ok and even then this means the gasket is ok.
actually, if the car isn't overheating then you have no problem naman
- Jan 2004
- 40
March 2nd, 2004 11:20 AM #12speedyfix, inde naman sya nag ooverheat, so its normal ba na bumalik water sa reserve tank, kasi dati inde namn sya ganun, worry ko lang baka mag overflow sya reserve, syempre sayang coolant :confused:
one more thing, feel ko mas hirap sya humatak pag nangyyari yon. :dead:
March 2nd, 2004 11:27 AM #13
siguro nga water pump yan or kung hindi man baka barado na yung radiator mo kaya't di gaano nakaka circulate mabuti yung tubig, pag kailangan nang palitan ang cylinder headgasket bumubula or tila kumukulo ang tubig sa reservoir kasabay ng pagkaubos nito dito. pero kung ok naman compression reading ng oto mo tyak hindi ito ang culprit
- Nov 2003
- 3,848
March 4th, 2004 09:01 AM #15just replace the water pump muna then if ganun parin check the head gasket. while the head is off the block, have it hydrotested narin for cracks and see narin kung warped or hindi. if it's warped, kahit palit ka ng gasket... masisira din sya.
