Results 1 to 10 of 11
- Nov 2003
- 89
March 10th, 2004 09:09 AM #1Guys tanong ko lang d ba masama yun d na gunagana ang temp dial ng AC ko? pag naka on na yun fan after alil while kahit d ko galawin yun dial lumalamig na sys, i got this car 2nd hand na eh so i think modified na yun AC ok lang ba ito or should i have it fixed para mabalik sa dati?
March 10th, 2004 02:32 PM #2
Saan ba nakaposition ang dial? And for what car?
Ang masama is kung hindi nag-di-disengage ang compressor after the system has reached desired temperature....
Normally hindi na dapat ginagalaw ang thermostat. Yung fan na lang. You'll just wear out the switch if you keep playing around with it.
- Nov 2003
- 89
March 10th, 2004 06:33 PM #3my car is a lancer 93 GLi kc kahit d ko pa ginagalaw yung dial lumalamig na sya e alam ko dapat fan lang gumana pag d pa na adjust yun dial d pa lumalamig yun hanngin dapat di ba? with my car fan control lang e malamig na agad yung hangin. with regards with the compressor ok lang naman sya
March 10th, 2004 09:15 PM #4
Min to Max ang controlled ng dial ng GLi. Walang off iyon. Walang heater ang GLi mo right? Ang fan only position ng mga Mitsubishi ay marked white. Kung walang white marking dun (puro blue), malamang walang compressor off yun.
Ang compressor off nun ay dapat push button (with a snowflake logo). Ganun kasi yung sa GLXi na ginagamit ko.
I would advise you just leave the thermostat 3/4 of the way to the full mark to reduce wear and tear on the said switch.
- Nov 2003
- 89
March 11th, 2004 03:26 PM #5Yup Tama po sbi mo, Markings lang nan dun tsaka yun snow flake button na may orange or green light depend on the type of setting you want for the compressor to engage ata yun. Ang problem ko lang po kc kahit d nga ako mag adjust or i-adjust ko yun temp switch e pareho lang ang lamig na lumalabas sa AC ko. Para bang constant na yung coolness nya. So yun blow na lang nung fan ang adjustable tsaka nga yun compressor engaging. Parang bale wala na yun temp switch.
March 11th, 2004 09:39 PM #6
The switch adjusts how long the compressor will stay on before...
Check mo na lang kung nagidisengage ang compressor niya after a while kapag nasa low setting ang thermostat switch mo. But that doesn't mean the compressor will never engage.
Pakinggan mo na lang.
Ako din fan switch lang ang nilalaro ko.
- Nov 2003
- 89
March 16th, 2004 01:57 PM #7Ah ok, so i guess wala naman sira or difference kung yung dial d na gunagana kc ok naman yung compressor, it disengage from tym to tym at pag naka orange light yi\un snowflake button matagal sya bago mag engage.
Thanx po for all rthe help =)
- Apr 2003
- 526
March 18th, 2004 09:09 AM #8anong masisira if di nagdidisengage yung compressor? yung compressor?
ano cause nito?
March 18th, 2004 02:09 PM #9
Kapag sira ang thermostat mo at hindi nag-automatic ang aircon, magiging frozen ang mga linya ng a/c mo which can cause it to crack.
- Apr 2003
- 526
March 19th, 2004 07:01 AM #10ummm, gaano katagal na operation bago ba mangyari to? Parang hindi nga yata nag-aautomatic yung aircon ng accord namin.
