Results 1 to 9 of 9
March 1st, 2007 06:25 PM #1
actually sir i already, or your shop already did. kaso ganun pa rin nga ang situation. low idle.
you advised na i replace my IACV. i went to Nankai as per your advise
kaso naka-limang palit na kami ng IACV unit ganun pa rin yung idle eh.
so hindi ako nagpalit.
kaya eto ako ngayon na naghahanap ng mga posibleng solusyon.
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 3rd, 2007 07:34 AM #2have the a/c checked siguro... what type of bulbs? baka kelangan ng relay.
March 10th, 2007 08:41 AM #3
Baka nga kinukulang sa ground. Saakin naman sa honda city ko pag nag on ng ilaw or anything na mag cconsume ng kuryente namamatay yung engine tapos check ko yung ground cable ko maluwag sa baterya after ko mahigpitan ok na siya ulit.
March 12th, 2007 03:54 PM #4
i tried the 'old school' birada of testing my alternator.
bukas makina, tanggal neg sa batt, bukas ilaw, dome light,
sounds. sa ilaw pa lang nag flicker na yung dome light. ganun din nung binuksan ko yung sounds ko. (no amps, so subs, just 2 tweeters from raon, the rest stock.)
ang finale nung binuksan ko yung aircon. yun na, namatay na makina.
kung mali ang technique ko ng pag test, paki correct pls.
could this be the reason kung bakit mababa ang idling ko?
or the other way around na this is caused of low idling?
Tesla Philippines
