Results 1 to 10 of 16
September 7th, 2004 10:37 PM #1
gys w/ Civic EK body, have you experienced getting water in your trunk when raining? it's because whenever it rains and i use the car, my trunk compartment gets wet. i can't seem to trace the source of the water. my best theory here is the water from the power antenna or water coming from the drainage vent just below the power antenna. it gets wet in that area only. i had my mudguards removed and i suspect water splashing from the tires enters the drainage vent.
have you guys experienced this before?
September 7th, 2004 11:13 PM #2
yup, friends of mine have experienced that also. check your tail lights also kasi baka di na siya naka-seal ng mabuti.
September 8th, 2004 09:41 AM #3
meron water drain hose yung power antenna, check if it's connected properly sa exit way ng tubig. normally it won't leak any water yan pag di nagagalaw except kung nabangga ka na at pinalitan yan.
September 8th, 2004 03:52 PM #6Originally posted by baiskee
agree with ssaloon, check your tail lights.
Tsikot Member Rank 3
- Jul 2004
- 1,540
September 8th, 2004 04:33 PM #7baka nga yung tail lights or yung antenna mo yung dinadaanan. was your car bumped at the trunk part before?
- Jul 2003
- 49
September 8th, 2004 09:57 PM #8Also check the rear bumper support/clip, the rubber gasket might be defective. That is No.17 in the drawing below:
<img src=http://www.slhondaparts.com/images/PCI/13S041/012/9.jpg>
- Jul 2003
- 49
September 8th, 2004 10:09 PM #9the drawing:
<img src="http://www.slhondaparts.com/images/PCI/13S041/012/9.jpg">
- Jul 2003
- 49
Tesla Philippines
