Results 1 to 8 of 8
July 10th, 2007 03:04 PM #1
what's wrong with sticky viscous belt fan?
I compared two same vehicles, when I turn off the engine, the belt fan still spins, while the other vehicle stops spinning immediately after turning off the engine.
should the fan locks up despite the engine is still cold?Last edited by rion; July 11th, 2007 at 12:25 AM. Reason: grammars as usual...
DIY to death!
- Jan 2003
- 451
July 10th, 2007 05:18 PM #2
DIY to death!
- Jan 2003
- 451
July 11th, 2007 05:36 PM #4AFAIK, silicon oil lang katapat nyan. Auto shops would know what this is.
July 11th, 2007 05:48 PM #5
rion, yung clutchfan ko, ganyan din ang prob.. may times na freewheeling siya sobra, ginawa, pinaalis ko, at pinadagdagan ko ng silicone oil.. mga 1-3, ikaw na bumili ng oil, 100-200 lang yun, sa cardomain(sa sig ko) ko shows kung panu nilagyan ng oil yung clutch fan...
mga 1-2 lang, kasi mahirap kung sumobra.. malalaman mo kung tama lang kung naiikot mo parin ang fan, pero di siya kasing luwag ng yuna mong inikot freely.. and dapat magkakaroon ng malakas na parang humihigop pag nirevolution mo...
ps to check kung kailangan na dagdagan ng silicone oil ang clutch fan:
patakbuhin mo ang makina....at idle speed and at running temp., not cold...
using a thick slipper, try mo pigilan ang fan.. kung huminto/napigilan mo, then yun ang sign...dagdagan mo ng oil..
pag lumaban yung fan pag pinigilan mo, means ok siyaLast edited by alwayz_yummy; July 11th, 2007 at 05:52 PM.
July 11th, 2007 05:55 PM #6
somebody told me a lubricant nga, silicon oil pala ang tawag nyan.
salamat sa info master Yoda.
coolness, I think I can D.I.Y from your webpage.
thanks alwayz_yummy.Last edited by rion; July 11th, 2007 at 06:04 PM.
July 11th, 2007 06:03 PM #7
welcome... check mo lang ung pics ko sa cardomain..medyo tricky lang alisin ang fan w/o disassembly ng seats,e...
July 11th, 2007 06:20 PM #8
no probs removing the fan. done it many times. it's the fan disassembly I'm worried. unchartered area pa yan sa akin.
buti na lang you have a documentary with pics.
Tesla Philippines
