Results 1 to 10 of 23
July 6th, 2018 11:01 AM #1
Ano kaya problema ng sasakyan ko?
Everytime after oil change naglalabas ng usok sa tambutso. Hindi naman continuous na mausok. Minsan pag ni-rev meron. Minsan kahit i-rev wala. Minsan naka-idle lang meron. Minsan wala. Pero after a few days/weeks mawawala naman yung usok. Smoke is parang bluish white pero manipis (hindi yung pang-smoke belcher) at nagdidissipate naman agad sa hangin. Tailpipe is damp. Checked oil level saktong-sakto lang sa max level sa dipstick.
Last 3x oil change ko na ito nanotice.
- Nov 2017
- 1,748
July 6th, 2018 11:21 AM #2
- Jul 2013
- 2,450
- Jul 2013
- 2,450
July 6th, 2018 11:44 AM #5I suggest you change your head gasket and valve seals and in the process inspect the piston rings na din.
- May 2018
- 611
July 6th, 2018 11:44 AM #6Gasket, piston ring or valve seals are failing. (either one or combination nito). Hindi pa naman sira, pero medyo may bumibigay na.
Pag na restore na yung compression & seal (lumapot na konti yung bagong oil) nawawala yung usok.
Grabeh, ambilis mag post ng mga Tsikoteers ah.Pag click ko (2 na nakapost ) kaagad!
July 6th, 2018 05:50 PM #7
thanks sa lahat ng nagreply.
madugo ba na repairs or checkup yung mga seals na yan, if ever?
July 6th, 2018 06:04 PM #8
whata the vehicle and year? diesel gas cng?
July 6th, 2018 07:35 PM #10
Check piston rings.
Might be loose that's why oil is getting into your exhaust system.
Might want to get a compression test done to isolate which one is failing.
Tesla Philippines
