Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Apr 2006
    Ano kaya problema ng sasakyan ko?
    Everytime after oil change naglalabas ng usok sa tambutso. Hindi naman continuous na mausok. Minsan pag ni-rev meron. Minsan kahit i-rev wala. Minsan naka-idle lang meron. Minsan wala. Pero after a few days/weeks mawawala naman yung usok. Smoke is parang bluish white pero manipis (hindi yung pang-smoke belcher) at nagdidissipate naman agad sa hangin. Tailpipe is damp. Checked oil level saktong-sakto lang sa max level sa dipstick.
    Last 3x oil change ko na ito nanotice.
    Nov 2017
    Quote Originally Posted by wewoy_romero View Post
    Ano auto mo?
    Mar 2004
    Blue smoke is not a good sign ...
    Jul 2013
    Jul 2013
    I suggest you change your head gasket and valve seals and in the process inspect the piston rings na din.
    May 2018
    Gasket, piston ring or valve seals are failing. (either one or combination nito). Hindi pa naman sira, pero medyo may bumibigay na.
    Pag na restore na yung compression & seal (lumapot na konti yung bagong oil) nawawala yung usok.
    Grabeh, ambilis mag post ng mga Tsikoteers ah. Pag click ko (2 na nakapost ) kaagad!
    Apr 2006
    thanks sa lahat ng nagreply.
    madugo ba na repairs or checkup yung mga seals na yan, if ever?
    whata the vehicle and year? diesel gas cng?
    Apr 2006
    It is a 2000 crv gas
    Oct 2017
    Check piston rings.
    Might be loose that's why oil is getting into your exhaust system.
    Might want to get a compression test done to isolate which one is failing.
Smokey tailpipe after every oil change
