Results 21 to 25 of 25
January 2nd, 2008 03:11 AM #21
Halos nagawa na pala lahat pero, may problema parin.
Okey dont be dissapointed.
You see, lahat ay nasabi na kung anong problema pero, there is one thing that you overlook. Kapag wala sa level ang kotse mas mataas sa kabila pero wala naman modification sa suspention your problem is the TORSION BAR. TORSION BAR are used to support your car suspension kapag itoy nawala sa level proportion of course magiging tabingi ang sasakyan kahit bago lahat ang spring or shocks mo. You have to bring it to the mechanic to correct (adjust) the problem.
January 2nd, 2008 07:13 AM #22
January 2nd, 2008 08:17 AM #23
Haaaaaa EK ba? WTF bulag kalaban.
Okey, check all your control arms bushing, rear inner, left and right your front lower arm. On the rear check also your rear suspension compensator upper left or right for bushing damage. Pudpod na ang mga iyan kaya palitan mo na. If this all fail, change your car bought yourself a new one......peace.
January 2nd, 2008 08:59 AM #24
- Jul 2007
- 25
April 15th, 2008 10:40 AM #25I have the same situation before and i found out na Shocks pla ung problem sakin.. so nung pinalitan ko ung shocks, ok na sya.
