Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
    Aug 2005
    ah..
    sir mazdamazda okey lng po yun ginawa ng servitek kasi sakin 4 times na ako nagpa align (waste of money) kasi nag pa change ako ng bagong tie rod-in tapos ng pa align ako pero may kabig parin sa right and until now hindi talaga makuha ng shop... assistant mechanic lng po kasi nagpalit ng tie rod-in so baka hindi na align ng maayos.. tama ba yun? ano source of prob po dito ? okey din nman yung front suspension ko... tsk tsk...
    mas ok get second opinion kung feeling mo your being fooled...
    ot: pina check ko yun rav4 ko e nakakainis kasi pag soli sa akin when i raise the hand break 3 click lang yun na, e 1 yr palang yun, im not stupid to run when the hand break is up, sabi nun boss kelanagn daw ganun sop daw yun turo sa japan, e medyo naiinis nako kasi thrice kona pinabalik driver namin, sabi ko babayaran ba nila gas, i dont see anything wrong naman so pinabalik ko sa dati dpat, then i compared ok lang naman, i tried hand break sa sloping ok naman di dumudulas...
    Nov 2003
    tama yan. you cannot correct the alignment if parts of the suspension are damaged. sasakit lang ulo mo and nila if they try to compensate on the machine for parts that have excessive play or are busted.
Racket or Not?
