Results 1 to 10 of 13
December 19th, 2005 04:04 PM #1
I went to this Goodyear Servitek to have my alignment checked (since my car is veering to the right after I went through a nasty pothole).
Curiously, instead of checking the wheel's alignment through the machine, the mechanic instead went on to inspect it manually. Then afterwards he then proceeded to check the front suspension of the vehicle. Their verdict? Busted ball joints and stabilizer link.
They estimated around P9K for the materials and labor.
What ticks me off is that they proceeded to inspect my vehicle for other damages rather than my main concern. My experience with them before was quite ok and I was quite surprised by this.
December 19th, 2005 04:31 PM #2
ganyan din sabi sa amin dati... naayos naman... kasi minsan daw kahit anong align di maibalik dahil sa ball joint
December 19th, 2005 04:33 PM #3
??? Try going to another shop to confirm it... while it's possible you could have acquired said damage, that IS strange... most often, the mechanic will put it up on the machine, align it, let you test drive it, and THEN check for damage after you've said the "pulling" is still there...
December 19th, 2005 04:43 PM #4
hmmm.depende siguro sa servitek bro. ako three weeks ago, went to servitek las pinas to have my rear shocks and bushings checked dahil may naririnig akong squeak pag uneven roads.
on checking my car, sabi nung mechanic, wala naman daw diprensya. proceeded lang to put silicon lubricant sa mga joints, tapos pina test drive sa akin ng kasama sya. dun, nawala yung squeaks, up to now.
FrankDrebin GuestDecember 19th, 2005 04:58 PM #5
HHmmm....afaik SOP talaga ng matinong mechanic na i-check muna ang condition ng suspension parts before alignment. Pero kung pinipilit kang papalitan sa kanila eh yun ang racket.
December 19th, 2005 05:36 PM #6
Tama, before conducting an alignment SOP na ang check nila ang condition ng lahat ng parts na related sa steering. Useless talaga kung mag-aalign sila ng may busted parts.
December 19th, 2005 05:37 PM #7
JLG,
standard routine yan sa servitek. they do that to protect themselves. Bakit kamo? may warranty kasi wheel and camber alignment nila. kung busted piyesa mo e hindi talaga tatagal yung alignment job nila. Di katulad ng iba, tira lang ng tira.
I had mine done at autocamp, finally they had my steering wheel centered to the tires hehe.
December 19th, 2005 06:05 PM #8
Originally Posted by pajerokid
Just to add, i'm happy with the Servitek Autocamp service...
December 19th, 2005 06:07 PM #9
hmmm... sige... kuha muna ako ng 2nd opinion dyan sa Servitek Autocamp.
la pa naman kasi akong nararamdaman ng sira sa front suspension ko. though at 56K km, baka due for a replacement na talaga yun.
