Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Dec 2009
    Hi guys! Ask ko lang kung may problema ba sa sasakyan ko or ganun talaga sa lahat. Kada kasi mapapadaan ako sa nag sisiga or nasa harap ko yung bus/truck na malakas mag smoke belching eh naamoy sa loob ng sasakyan yung baho. Ano sa tingin nyo? Thanks
    Posted via Tsikot Mobile App
    Jun 2010
    punta ka sa ac shop and pa close mo yung outside air vent located sa may cowl, alam na agad ng ac shop yan.
    Dec 2009
    Thanks sir! Wala bang side effect pag pina close yung outside air vent?
    i read somewhere, that as a safety precaution, the vents are designed so as not to allow one to completely close the passenger cabin from incoming air.
    ... lest we all die of suffocation (carbon monoxide poisoning).. that engine in front of us is a very potent CO generator..
    Nov 2007
    Naeexperience ko rin yan sa Outlander ko dito sa Bahrain lalo pag napapadaan ako sa mga sewage pumping stations. Pero yung montero at mirage hb namin eh hindi naman..
    Nov 2007
    Nakita ko sa www.aa1car.com:
    If your car has a cabin air filter, noticing outside odors is a symptom that the activated charcoal in the cabin air filter has probably reached the end of its service life. Activated charcoal can absorb odors, but it only lasts about a year or so. Better check your cabin air filter and replace it with a new one if it is more than a couple years old. See your Owner’s Manual for the location of the cabin air filter (it is usually buried behind the glove box or is located in the cowl area at the base of the windshield).
    You can just open the window for fresh air or to recirculate cabin air if on a long drive.
    Quote Originally Posted by radz15 View Post
    Wala! Usually ganyan talaga problema ng old cars.
    Dec 2009
    2011 adventure GLX po sasakyan ko. Is it considered old although old model na body nya. Thanks sir
    Jan 2011
    baka nakabukas ang air recirculation. isara nyo lang po yon.
Pumapasok ang amoy/baho sa loob ng kotse
