Results 1 to 9 of 9
    Aug 2003
    my ride never really felt like it accelerated very well, and i've blamed this on improper shifting on my part. pero recenly kasi napansin ko na at certain times, it seems a lot more responsive than usual -- dati rati kasi you can feel a slight delay between pushing down on the gas and the car actually going faster. at certain moments kasi ang ganda ng response. wala naman akong pinalitan. problema kaya to sa timing?
    it could also be the fuel you are using.
    btw when was the last time you had a tune-up?
    Aug 2003
    benchph1::btw when was the last time you had a tune-up?
    um....never? ;) seriously though, the last tuneup was in the 90's pa...
    hehehe... pa tune-up ka na... kayla speedyfix kaya yan...
    Nov 2003
    never? hehe! ok ah!!!
    actually, replacing the plugs, air filter, fuel filter and oil is most of the maintenance a car usually needs.
    replace all of that and you shouold feel new vigor in the way the car drives.
    After you have replaced all of the things mentioned above, have your timing checked. The acceleration lag that you mentioned may have something to do with timing that is a bit retarded.
    really, never? swerte ka at ganyan lang nangyari. hehehe
    can i ask, whats the ride of the thread starter? curious lang..
    Aug 2003
    a very old '89 corolla ;) bale napa oil/fuel filter/spark plug/air filter change ko na sya lately, but sadly DIY lang(i have a front yard with huge oil stains to prove that), ung timing never ko pa nacheck
problem with timing?
