Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    the past six months, parating napuputulan ako ng power window cable (driver's side).
    nung una, last november, tapos last month, tapos kaninang umaga on my way to work.
    normal window opening lang naman (pag nagbabayad sa tollgate) ang galaw nya. there must be something wrong with the cables used for repair or something which i use the window.
    pano ba maiiwasan ito? do i need to have it fixed using thicker cables?
    may mga nakaka experience na din sa inyo nito?
    yun cable lang talaga ang napuputol? or nababasag din yun mga pastic parts na naghold sa cable?
    baka kulang lang sa grease..naiipit siguro...
    kung yun plastic nag crack...nasasandalan siguro yun window
    yung cable lang parati bro. does it mean i need to grease them up regularly?
    Sep 2004
    Bro, try mo Shimano cable, like the ones they use for mountain bikes (brake and shift cable). Matibay at recommended din ng mga power window technicians.
    Pareho lang kasi yun ng mga power window cable. That's what they used sa power window ko, kasi madalas magbuhol-buhol before kaya napigtas eventually. More than 2 years na, ok pa rin. Tapos, as preventive measure, apply silicone grease sa run channel para madulas.
    Jan 2008
    tama sila sir, try a stronger cable and at the same time lubricate parts that needs to be lubricated.
    Quote Originally Posted by Galactus View Post
    yung last cable ko (last month) ako bumili, pang mountain bike ang binili ko. hindi nga lang shimano (mukhang taiwan).
    siguro ang kulang nga is yung greasing.
    Pre ayaw mo ba palitan na lang ng whole assembly, one time gastos
    Quote Originally Posted by 1D4LV View Post
    hinde naman regularly, but once in a while won't hurt...pag meron kang time ang sinipag lang then remove the sidings and lubricate mo...but hinde naman kailangan na meron fix schedule...sabay mo na rin mga hinges ng doors...
    Quote Originally Posted by artpogi View Post
    bro, mahal.... i think it costs more than 3k. hirap din bumili ng surplus dahil ganun din, baka maging sirain lang.
    *shadow: thanks bro..siguro nga ganun na lang gagawin ko. and iwas bukas na lang muna... pag bayad sa tollgate bukas pinto na lang as much as possible.
    * 1D4LV:
    bro, san ka nagpapagawa, ok ba trumabaho?
    my power window also has a problem. . .derailed sya so may awang sa bandang taas pag isinara. . .hindi kasi naayos nang husto dun sa pinagdalhan ko lately. . .ang advice e palitan ko raw yung goma which costs 3.5 k petot daw. . .tanong muna ako sa iba. . .
    anybody know kung saan sa banawe pwede pumunta for this kind of problem?. . .thanks in advance. . .
Power Window Cable - Parating Napuputol
