Results 1 to 10 of 10
June 15th, 2003 06:30 PM #1
nakatambak lang kasi sa likod ng garahe namin yung set ko eh. if ever this happens, what can i do to undo the damage done and prevent it from happening again? will it affect the performace or ride quality of my car? sorry kung daming tanong, need your advice.
tnx! :D
- 10
June 15th, 2003 09:23 PM #2possible pero superficial lang not to the extent na maapektuhan yun strenght of material.
i think the material used for coil spring is similar to that of brake disk
June 15th, 2003 10:40 PM #3
it will rust since its steel...
to prevent rust, clean off existing rust and rub some oil all over it. Keep in cool & dry place.
June 15th, 2003 10:45 PM #5
it would... just make sure its done after you remove all the rust first.
June 15th, 2003 10:55 PM #7
here's an example...
I have my stock disc brake rotors in my room in a cardboard box. Its been there for more than two years but there is minimal rust on it. Its stored under my bed lang. I didn't even have to oil it.
June 18th, 2003 12:14 PM #8
Make sure you coat the springs with primer first so that the paint will stick well. :wink:
June 19th, 2003 02:54 PM #9
undercoat paint will do.....medyo messy pero walang kalawang
unlike paint pag tumagal papasukin din ng tubig then mag rust na
- Mar 2003
- 91
June 21st, 2003 01:41 PM #10hmm.. possible mangalwang ang lowering springs pag natangala ang pintura nito.. pero matagal siya matangal cause its powder coated..
pa powder coat nlang kayo ng lowering springs.. yun tlga ung ginagamit para sa springs..
Tesla Philippines
