Page 14 of 22 FirstFirst ... 4101112131415161718 ... LastLast
Results 131 to 140 of 217
    #131
    wala ako sinabi dito ka magpavulcanize eh taga south ka.
    what im trying to say ive got it all in true qc.
    from low price fuel, pamurahan supermarket, pasarapan bakeshop.
    Ang point bakit mga lugar nyo hindi kaya magbagsak presyo na may respetado pwesto??? 200 tapos bangketa lang!!!!
    eh kung pababaan na lang ng amillar?
    lecheflan dito, 70 kesos na, napakasarap pa!
    40 pesos lang ang singil ng SM manila parking. laging may bakante na, malapit pa sa workplace!
    jan sa inyo... 50 pesos na, malayo pa sa workplace, paiyakan pa sa hanapan ng slot!
    'yang pinagmamalaki mong tyre shop... ang nag-pasak sa tyre ko! palpak pa, dahil nag-leak ulit!
    doc,
    i only entertain leche flan that uses duck yolk & carabaos milk.
    Ano yung sabi mo pasak? Sa pinapagawan ko patch only.
    parking in qc sa majority establishment eh free. Sa pay parking pag senior citizen free 3hours.
    doc jan sa manila ginto parking mas mahal pa sa makati hahaha. When i say manila = ongpin at quiapo the most expensive paradahan
    #133
    doc,
    Free parking for seniors 3 hours lang? Diba sa ibang city sa South free talaga seniors kahit whole day?
    Jun 2005
    #134
    Dito lang samin sa may city hall kags
    matinong vulcanizing pag ganyan. Saan part ng makati?
    Usually pag makati =scam, hype, pasosy
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    sha,
    oo 3hours free sa magnolia, mezza, sm north, trinoma.... basta any pay parking libre 3hours.
    Sa ano south yan sabi mo? Baka sa alabangaw towncenter yan???
    #136
    doc,
    it's ok.
    what you don't know, you don't know.
    it's common knowledge, car parking for commoners in binondo is next-to-impossible.
    but there's much more to manila than ongpin. widen your horizons, kags. 'wag maging estranhero sa sariling bayan.
    and you're not a senior citizen.
    do not assume their privileges will rub off on you.
    #137
    sha,
    FREE Parking to all Senior Citizens and PWD’s in Muntinlupa? Find out details here. – Alabang Bulletin
    from the article
    We heard somewhere that the free parking will only be for the first three hours though but we’ll update this post as soon as we’re 100% sure.
    Nangaya sa true qc ko.
    Apr 2016
    #139
    Bago ko bili and install new tires. I need to make sure ayus yun pasak na gawa para in case the tires end up with a new user. Hindi ma cause ng harm.
    So bumalik ako sa service center to ask what exactly the oil used and if they really used any adhesive or not. The technicians who did them confirmed ATF (Automatic Transmission Fluid used) was put and no adhesive was used because they didn't stock any rugby. So I told them to buy a bottle of adhesive (and waited) so they can re do the plugging.
    Ito binili nila na adhesive.
    Click image for larger version.
Name:	rubber cement.jpg
    I asked them what exact plug they used. They showed me this.
    Back of box.
    ito loob.
    I told him to remove the original string plug and put new string plug with rubber cement used and not put any ATF.
    This is the attempt at removal of the plug (please note if the hole is damaged further and what kind of damages).
    In the video, the technician tried to convince me meron daw sariling pagdikit yun string pug (kasi it feels sticky). Is it true?
    This is when the new plugs were inserted with rubber cement applied.
    here the technician tried to convince me the purpose of the rubber cement was just to make it easy to insert, as lubricant. That's why they substituted with ATF. Tama po ba? Diba the main purpose ng rubber cement is to bind them?
    What is your comment about the removal of the old plugs and insertion of the new string plug? May old plug bits natira sa loob ng hole surfaces? If hindi ok, then I'd just destroy the tire so it won't end up with new owner. I told them to redone the pasak for sake of a new user who may happened to buy it. Ikaw, bilihin mo ba yun tire na na 2nd pasak above? Dati I bought 2nd hand tires kasi wala ako budget.
    A new tire shop is asking me for 2000 pesos for the 4 tires to deduct from the 4 new tires. Saan ba puwede ibenta mga 4 old tires ko na more than 2000? (500 pesos each)? Ok new tires na Toyo 225/60 R17?
    #140
    Hindi pa din maka move on?
    Signature
Plug (pasak) then Patch (tapal) on tire?
