Results 1 to 5 of 5
- Jan 2007
- 2
January 8th, 2007 11:34 AM #1ask ko lang kasi yung sasakyan ko old model ng toyota tamarraw UV 1989, 4k engine...mahina na kasing humatak and may tagas...im not sure pero sa tingin ko oil seal ang problema kaya may tumatagas...i badly needed help guys...send me advice kung san pwede ipa-check up and estimate...thx
- Jan 2007
- 2
Zombie
- Aug 2006
- 728
January 8th, 2007 05:40 PM #3oil seal and gaskets yan. it's an old engine too, so may tendency talaga for it to lose compression.
for the gaskets and seals, most of the shops kaya gawin yan. i believe umuusok na ren ang exhaust mo? you better have your vehicle checked by a decent service center. marami pa mahahanap na problema yan. as for mahina hatak, pa-compression test ka. pag lahat ng cylinders mo bagsak, you have to have it overhauled, which will be expensive. you might consider changing the engine too.
ganyan talaga pag luma na ang sasakyan, lalo na kung hinde continuous ang maintenance na ginawa
January 9th, 2007 02:32 PM #4
It's so not easy to assume in your situation... it could be one of too many things...
Why don't you go to a shop and get a compression and leakdown test???
