Page 1 of 3 123 LastLast
Results 1 to 10 of 21
    ano kaya pwede gawin para mawala ito? nakakainis kasi pag umaandar na ang kotse, ang ingay! wd40 kaya?
    It may be coming from your drive belts. Have the belt tension checked. Kung galing per se sa front seats WD40 nga katapat niyan.
    galing tlga sa seats kasi when i hold them still, walang tunog eh.
    Jul 2003
    TRy applying wheel bearing grease. it lasts longer than wd40
    tighten the bolts and spray generously with wd40. earbuds? ;)
    You could also try putting some teflon tapes on those bolts, minsan maluwag na yung bolts due to the aging of the vehicle. Then re-tighten all other bolts supporting it.
    bat naman kasi sa front passenger mo ginagawa eh he.he
    ako naman kapag naka-aircon lang tapos I reach around 3500 rpm meron parang kuliglig dun sa right rear passenger side door. damn
    Tinanggal ko na yung sidings ko last week to check and tighten everything pero ganun pa din.
    The noise emates from the right rear passenger door tapos will spread sa front passenger.
    Buwiset talaga. Hirap pa naman maghanap ng mga ganyan unusual sounds.
    squeaking sound ba o parang kumakalog?
    pag may passenger ka ba maingay pa din? kung nawawala yung squeaking sound pag may naka-upo, e di dun ka na lang umupo! j/k.
    seriously, had that same problem in my gen1 pajero before. ang dami pa namang bolts, springs, moving parts ng seats non.
    wd40 would do the trick, pero temporarily lang.
    yung sakin pati springs nilagyan ko rin ng wd40, siguro after 3 months bumalik ulit yung squeak, so lagay ulit!
    Yung recline handle ng passenger seat ko ang cause ng noise. Yung sa L300 naman dati nag-ipit ako ng diyaryo between the steel seat spring and the foam underneath. Ok naman. Nawala. hehehe.
Annoying squeaking sound from front passenger seat!
