Results 1 to 10 of 16
- 152
December 9th, 2002 07:05 PM #1bat ganon bigla na lang nagloko idling ng mazda 323 ko.
normal naman sya for the past months tapos yesterday pag open ko ng aircon (na warm up ko na yung car for abt 10mins) biglang 600 na lang rpm ko kaya ang lakas ng nginig tapos pag pinatay ko 900rpm which i think is normal. bat ganon?
before 900 yun rpm ko tapos pag naka aircon 800rpm. biglang naging 600. wala naman akong ginagalaw. nagpatune up ako last aug2002. nilinis na din carburetor ko using the spray carb cleaner. ano na naman kaya problema na kotse ko?
- Nov 2002
- 50
December 9th, 2002 08:06 PM #2once bumagsak ang idling ng 600rpm, kapag ni-rev mo ba ng konti bumabalik ba siya uli sa normal? if yes, check the choke of your carb, baka stuck-up lang...
pag ok ang choke, check the idle-up (actuator)... ito yung nagpapa-taas ng idling kapag nag-on ang compress to compensate for the extra load...
December 9th, 2002 11:01 PM #3
Coolgal::: I think yung compensator ng aircon mo kailangan i-adjust. You can do this yourself if youre mechanically inclined. Turnilyo lang ito na pipihitin mo to adjust the idle when the compressor is running
December 10th, 2002 06:28 AM #4
Baka yon idler up sira na. Is it permanent or intermittent? If intermittent, check connection between your AC compressor and your idler up switch. Baka loose lang. Good luck. :wink:
- 152
December 10th, 2002 12:58 PM #5pag ni rev ko bumabalik din sya sa 600. before naman bumabalik sa normal pag ni rev ko pero ngayon di na. pag nag automatic na yung fan bumababa sya ng 600 tapos pag nag off na 800 na ulit tapos pag nag kick in yun fan 600 na naman. ano sasabihin ko sa mechanic? i-check yun idler up switch? pano kung kailangan na palitan? magkano yun?
December 10th, 2002 01:09 PM #6
Malamang sa idler up switch lang yan. Nung nilinis ba yung carb. mo e tinanggal yung buo? Kung ganun, baka hindi nila naibalik yung vacuum hose na nagpapa andar nung idler up switch (kung vacuum type) o kaya baka hindi naibalik o nabunot yung wire ng idler up (kung electronic type).
Sabi nga ni OTEP, kung machanically inclined ka madali nang i-DIY yun.
Good luck sa problem hunting. :mrgreen:
- 267
December 10th, 2002 01:59 PM #7yup! sa aircon idle-up lang yon! check yung vacuum hose nito baka nabunot lang!
- 152
December 10th, 2002 05:22 PM #8so ibig sabihin simple lang problema ko... haay salamat. sana nga yung sinasabi nyo lang yung problema. tagal na yung tune up ko august pa ata bat ngayon lang nag react? yung vacuum hose na check ko na ok naman nakakabit sya. i tried adjusting the screw, bumaba yung rpm tapos binalik ko bumalik sa dati pero pag on ng aircon 500-600rpm talaga sya kahit nilagy ko na sa 1300 yung rpm pag open ng aircon nagddrop sya sa 600. that whats bothering me. :roll:
- 14
- 152
Tesla Philippines
