Results 1 to 10 of 11
- Nov 2002
- 194
July 18th, 2003 05:08 PM #1guys,
I will be out of the country for 4 weeks and walang gagamit ng car ko...wala rin pwede mag-start every morning...ok lang ba sa engine yun? also, di kaya ma-oblong yun tyres ko?
thanks for your feedbacks.
July 18th, 2003 05:17 PM #2
when i went out of the country for a month before, wala ring gumamit ng car ko, at wala ring nag-start, pero nung pagbalik ko, ok naman.
as to the tires, di naman sila ma-oblong.
- 3,754
July 18th, 2003 05:27 PM #3Kung 1 month lang OK pa siguro.. sakin nga 2months ok lang,, every week lang start
July 18th, 2003 06:22 PM #5
if paranoid you could also get a set of jackstands to lift your tires off the ground.
July 18th, 2003 09:44 PM #6
wag mo tanggalin yun battery terminals, e di wala na alarm.
ok lang yan, ako every month din umaalis, 1 month din ako wala. ok lang naman battery saka tyres.
ang masama kung gaya nung sa friend ko, vr4 na galant e sa condo nakatira sa may likod lang ng shangrila. e di lakad lang nila ang megamall etc. so minsan 6 months nya di ginamit kotse yun palit sya ng gulong at nag-crack na yung rubber hehehe. ngayon naka jack stands na. di pa rin nya ginagamit kaya kahit na 5 yrs old na kotse nya di pa umabot ng 20,000 kms! sabi ko nga bilihin ko na lang e hehehe, ayaw naman.
July 19th, 2003 01:08 PM #7
1 month is OK...
- change the oil and filter (if it hasnt been done recently) so there wont be muich dirt and sludge inside to settle.
- top up on gas before you leave it.
- You may not have to jackstand the car but fill up on air to around 33-35psi cold (and make sure tehre are no leaks).
- It would also be a good time to wash and wax before you leave the car. Clean the interior and engine bay as well.
- put some rat poison also in the area near the engine bay or in your garage to prevent the rodents from building a nest in your car
July 20th, 2003 02:41 PM #8
isa ring option nyo sir is to have your car parked at MIA Caltex - Park 'n Fly...malamang meron silang packages para sa car maintenance....
July 20th, 2003 03:20 PM #9
Um, iwan mo sa MARC Caltex sa Pedro Gil.
July 20th, 2003 07:37 PM #10Originally posted by OTEP
