Results 1 to 10 of 24
- Oct 2013
- 1,181
January 10th, 2014 06:46 AM #1Marami factors yan, check mo yung idle rpm mo kung nasa normal range.
Check mo rin kung kailan last mo na PMS. Kung recent lang, ipa-scan mo sasakyan mo.
- Jan 2014
- 158
January 10th, 2014 09:33 AM #2San maganda magpa scan for maintenance? CASA ba? malapit ako Toyota Alabang , ive got 165KMS on my odo
ive notice maluwag din yung idle ko papa adjust ko mamaya may nagpakita sakin na maluwag hehe thanks mga ka tsikot!
January 10th, 2014 09:50 AM #3
- Jan 2014
- 158
January 12th, 2014 08:41 AM #4
- Apr 2017
- 11
April 15th, 2017 08:39 PM #5Pls. Help. I bought a brand new toyota vios e at 2015. I noticed a vibrating sound from my dashboard. I already referred the issue to the service center. They told me they put some padding in the steering wheel to correct the issue. After i took the car from the service center, the problem still persist, the noise and the vibration from the dashboard is still there. Pls help, have you experience this problem before? Did someone experience this problem before?
April 15th, 2017 08:41 PM #6
no missed engine oil change? whats the mileage on the odometer?
- Apr 2017
- 11
April 15th, 2017 09:13 PM #7Hello. I just had my 10k pms last week. Its the time I open the problem to them. Mileage is 10k. I am told its the steering wheel thats vibrating in which theyve put a padding but when i drove the car the vibration is still there. I noticed that the problem manifests when the road is not asphalt. I just cant bear the vibrating noise, this is suppose to be brand new, why am i having this problem. Pls help. Pls share ur thoughts on this problem.
April 15th, 2017 09:14 PM #8
A few other things to check:
Engine mount
Fuel quality
Dead or intermittent cylinder (bad sparkplug, ignition coil pack, or fuel injector)Last edited by oj88; April 15th, 2017 at 09:16 PM.
- Apr 2017
- 11
April 15th, 2017 09:26 PM #9Hello. I just had the 10k pms for the car. I was told its from my steering wheel after they test drive it. Unknowing of whats happening i gladly agreed in their solution in which they put some padding on it. After the 10k pms and the installation of the padding i drove back home. After 2 days the problem persists. Pls help. Mileage of the car is 10k. Im no expert in this field. Im getting paranoid of this weird sound from the dashboard. Pls help.
- 53,883
April 16th, 2017 02:37 AM #10make your own investigation, po.
exactly where is the vibration? what is causing the vibration? sometimes, when our hand or finger holds onto the cause of the vibration, it stops vibrating.
in my (non-vios) car, my dash vibration was traced to the swivel axis of the glove compartment. na-tanggal yung felt tape. linagyan lang muli, at nawala na vibration.Last edited by dr. d; April 16th, 2017 at 03:32 AM.
Tesla Philippines
