Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Dec 2009
    Need help! Especially sa mga naka Adventure. I'm about to replace my power steering fluid ang nalagay sa manual na ang dapat kong gamitin is ATF dextrone or dextrone II. Pero sa mga suking auto supply STP power steering fluid lang ang available. Is it ok to use the STF? Sabi nila universal daw un. Or kailangan ko talaga mag hanap ng ATF dextrone or dextrone II? TIA!
    Just go with dexron II ATF. Marami naman yan sa mga ibang auto supply or hardware store sa mall.
    Dec 2009
    Thanks! Try ko maghanap
    Dec 2009
    Bigla ako naguluhan. Pumunta ako kanina sa casa tananong ko gamit nilang power steering fluid. Sabi nila yung pang power steering na daw. Di na daw sila nagamit ng ATF dextrone or dextrone II. Iniisip ko baka pwede na yung sa STF na power steering fluid.
    Apr 2012
    Hanap ka bro sa Ace hardware. Maganda yung Mag1 na brand
    Aug 2012
    I will follow the owner's manual first and foremost.
    If wala ka mahanap na Dexron or Dexron II, you can use Dexron III. Dexron III is generally backward compatible with Dexron. Below are ATF compatible with Dexron III.
    Castrol Transmax Multivehicle ATF * P350+
    Caltex Texamatic 1888 ATF
    Petron ATF Premium
    Top 1 MV ATF
    Top 1 Super ATF DM-3
    Top 1 Lifetime ATF (Dexron)
    Valvoline MaxLife ATF
    Petron ATF Premium
    Top 1 MV ATF
    Dec 2009
    Thanks guys!
    Marami version mag1 atf. Their ulv(ultra low viscosity) atf is not suitable on most old vehicles.
    Apr 2012
    Mas okay siguro kung Mag1 na PS fluid nanlang bilhin ni TS 😄
    May 2011
    Buy mag1 psf mas maganda yan kesa sa atf for power steering mas smoother while turning
ATF for power steering fluid.
