Results 1 to 9 of 9
    Nov 2006
    Ask Lang I Own A 95 Glxi Matic Lancer, Pag Nag Aircon Me Humihina Ung Hatak Nya. Ano Kaya Problem Nun? Thanks
    Sep 2006
    Quote Originally Posted by pgokou View Post
    Normal yon kasi kelangan i drive din ng makina ng kotse yung belt para sa condenser ng a/c..
    Nov 2006
    pero dati di naman ganun humuhina cya pero di 2lad ngaun hrap humatak. pwede ba sa belt un?
    your a/c compressor being driven by the same belt as the engine might need oil replacement as it tends to lose some in time. could be the servo kit orthe idle up mech as well...have it checked by a car aircon expert
    Jan 2003
    i think you should check the bearing/s of the a/c compressor.
    Aug 2004
    That's where I'd start, too... excessive compressor drag means something's going to break soon.
    Nov 2006
    thanks,pacheck ko ung compressor,may tanong pa din ako pagtumatakbo ako ng 100km/hr may kumakalampag na pwede kayang ung compressor din un or ung engine support etc..? last san ba magandang magpagawa ng compressor?im from pasig......
    Nov 2003
    pa check mo kung may sayad yung compressor. it might be causing the weakness ng makina...
    Nov 2006
    Pwede rin yang vacuum switch.
Low Power
