Results 1 to 10 of 15
- Feb 2007
- 60
January 24th, 2008 12:19 PM #1Hi Guys,
I am just wondering... Would there be any significant improvement in my car's fuel consumption if I change from carb to efi (corolla gl 90)? Any idea how much it would cost?
TIA
Manley
January 24th, 2008 01:06 PM #2
It will not be easy nor cheap.
There is too much to retrofit.
I suggest you buy an EFI engine instead.
January 24th, 2008 02:13 PM #3
the fuel consumption will not be that great. very minimal lang yan. if you are averaging around 10 kms/l sa GL mo, ang magiging difference lang nyan is around 1 km/l and besides as 4JG said, it would be very expensive on you. for one, the carb engine walang ECU yan, and one of the requirements of EFIs are the ECUs which regulate the flow of fuel automatically and control the burst of fuel into the engine.
benta mo na lang oto mo ang get an injected variant.
January 24th, 2008 02:26 PM #4
Changing engines to lower fuel consumption is not cost effective bro. Regular maintenance at wag masyadong todong apak sa gas pedal na lang para makatipid.
January 24th, 2008 02:32 PM #5
January 24th, 2008 03:40 PM #6
I think a full engine swap would be the best way to do.. time for a 20 valve 4A-GE!!! hehehehe. youll get more HP but say sayonara for fuel economy! lolz!
anywayz, on a serious note. you can swap a 4A-FE in there and be done with it. it will be reliable, powerful and much efficient than your current engine IMHO.
aite, peace.
- Feb 2007
- 60
January 26th, 2008 07:32 PM #7KBR, Artpogi, mazingerz, 1D4LV, 4JGtootsie...
Thanks for your inputs. Very very helpful. I'll just save some more then upgrade to a newer model with efi.
Thanks,
Manley
January 26th, 2008 08:45 PM #8
it would not be practical to convert a carbed engine to an efi due to high cost. change engine would be the best.
January 27th, 2008 01:43 AM #9
i suggest try using kia B1 carbs. you simply need an adaptor for it to fit. any machine shop can do the conversion. with it, im sure you can feel the difference.
Tsikot Member Rank 4
- Jun 2006
- 2,605
January 27th, 2008 10:20 PM #10You might want to convert to LPG. This will give you money saving per liter of fuel. You save around P11 per liter. Check out the LPG thread for more info.
