Results 11 to 20 of 22
May 28th, 2003 09:34 PM #11
Originally Posted by chieffy
May 29th, 2003 02:37 AM #12
12 per fitting na lang sa Shell Retiro? Dati 14 ha. Buti pala hindi ako natuloy dati. hehehe.
Hindi basta basta maalis ng underwash ang grease. Most of them are inside the components or are protected by rubber boots/grommets. Yung grease gun nga nahihirapan i-force out yung old grease, eh.
May 29th, 2003 08:46 PM #13
tanong lang po..
lahat ba ng pajero kailangan ng lubed sa fittings.. .. yung sa akin 3 doors.. yung converted na pajero.. ano nga pala ang local term ng fittings baka kasi hindi maintindihan pag sinabi ko fittings he.he.. ;) and ilang fittings meron ang pajero..
pasensiya na ha..dont know what is fittings kasi eh..
marwen
May 29th, 2003 09:30 PM #14
marwen,
The gas station will know these fittings. Techinically they are called zerk fittings or grease nipples. Alam din ng gas station iyon. Almost all truck-based vehicles have fittings that can be lubed.
More than ten fittings ang naaalala ko. Hindi ko kasi makita yung listahan, eh. Meron sa front and rear drive shafts (both ends of both driveshafts pa ata). Sa pitman arm, sa ball joints and kung saan saan pa. Usually concentrated sa front suspension.
- Jan 1970
- 396
- Jan 1970
- 164
June 14th, 2003 03:26 PM #19Always check that they are changing the grease in all the fittings. There are some fittings that are hard to reach and they might just say that they did them when you're not looking. Alam mo naman ang ibang mekaniko pag di mo kilala...minsan tinatamad.
Tsikot Member Rank 3
- Dec 2002
- 636
June 15th, 2003 07:47 AM #20An alternative is to buy your own grease gun (about P400) with flexible rubber tip and specific grease cartridge. Gives you the option to buy special grease, eg, grease with moly, synthetic grease rather than the regular gas station grease. You can grease up whenever you feel like it!
